RS Turbo owners, Fan Switch news!
Old 19-01-2010 | 04:10 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default RS Turbo owners, Fan Switch news!
We have been working on an uprated fan switch for these for some time, which will bring the fans on slightly earlier, and bring the temps down slightly lower before switching them off. we see lots where the coolant temps are way too high and the same principle has worked really well on the cosworths,
As an added bonus, we were aware of the problem with the switch plugs being broken and burnt, so we have worked to get a switch which comes pre wired with no plug. so you can throw your standard plug in the bin, and connect our new switch direrctly to your loom!
Im currently testing them, So watch this space, they should be released soon!
Old 19-01-2010 | 04:51 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Look forward to seeing them, good work!
Old 19-01-2010 | 04:52 PM
ste45's Avatar
ste45
wouldnt mind one of these , how much will they be ?
gaz s1's Avatar
gaz s1
i just run a manual switch problem solved
Old 19-01-2010 | 04:55 PM
JTECH James
Passion for Fords!
Hopefully under Ł20
Old 19-01-2010 | 06:50 PM
morph's Avatar
morph
Originally Posted by James @ M Developments
Hopefully under Ł20
can you do one for aftermarket alloy rads as mine doesn't have a fan switch hole?
Old 19-01-2010 | 06:56 PM
JTECH James
Passion for Fords!
the std switch is on the head!
Old 19-01-2010 | 07:07 PM
haz87's Avatar
haz87
Is it not in the thermostat housing? The sensor in the head is for the temp gauge iirc?
Old 19-01-2010 | 07:08 PM
JTECH James
Passion for Fords!
yes, on the stat housing on the head
Old 19-01-2010 | 07:19 PM
JonnyC48's Avatar
JonnyC48
Look forward to seeing the finished product and will give me peace of mind not having to constanly watch the temperature gauge and using my manual switch.
Old 19-01-2010 | 07:26 PM
G420 DEL's Avatar
G420 DEL
good work james... anythin to help the temps is good!
stwibs's Avatar
stwibs
what temp you hoping to bring the fans in at?
Old 19-01-2010 | 07:29 PM
marky_g's Avatar
marky_g
Fleet Manager
hurry up i want 1
Old 19-01-2010 | 08:06 PM
mr_joe0606's Avatar
mr_joe0606
i want 1 let use no when you have them
joe
Old 19-01-2010 | 08:31 PM
nigel b's Avatar
nigel b
why not just use a relay to control the fan via the switch
Old 19-01-2010 | 09:18 PM
JTECH James
Passion for Fords!
you can, but that doesnt change the operating temperature
Old 19-01-2010 | 09:41 PM
alangti's Avatar
alangti
Old 19-01-2010 | 09:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Classic Morph!
Old 19-01-2010 | 09:50 PM
morph's Avatar
morph
Ok cheers, mines been wired to a switch but i couldn't see why fan did not come on auto aswell. must have disconnected the fan switch wires.
Old 19-01-2010 | 09:52 PM
morph's Avatar
morph
Originally Posted by Karlos G
Classic Morph!
sorry but i didn't know that it was in the head! mine is not coming on automatically, the guy i bought the car from told me it was because the rad was an alloy rad.
Old 20-01-2010 | 12:13 PM
JTECH James
Passion for Fords!
im aiming to get the fans in at 92 degs
Old 31-01-2010 | 06:50 PM
ste45's Avatar
ste45
how long until these go on sale ?
Old 31-01-2010 | 06:57 PM
JTECH James
Passion for Fords!
2 weeks max hopefully
Old 31-01-2010 | 07:38 PM
gus's Avatar
gus
would you still be able to do them as a seperate switch? no loom?
as ihave had a custom loom made and would rather not cut into it
Old 31-01-2010 | 08:49 PM
Rob_DOHC's Avatar
Rob_DOHC
you could just buy a connector from the bay and wire the switch onto that????
Old 31-01-2010 | 08:54 PM
gus's Avatar
gus
thats an excellent idea
simpliest are always the best
only thing being, i have paid a shel load of monies for a loom that is measured and fits perfect, so adding extension looms is not something i wanna do
Old 31-01-2010 | 11:47 PM
Rick's Avatar
Rick
you could do with testing if different loads (ie non std fans) effect the switch on temperature if these are a passive device. The ECU does mine, but before that i noticed that different fans could vary the switch on temp.
Rick
Old 01-02-2010 | 06:53 AM
Chris69's Avatar
Chris69
great news, i'll be wanting one i would imagine- essential mod if you make it work
Old 02-02-2010 | 09:04 PM
Rob_DOHC's Avatar
Rob_DOHC
Cool cool lol,
If it were me.... I would probably use a short length of wire from the switch like an inch, then s bend the wire so that the connector is sitting under the switch, cable tie or epoxy in place, and plug in..... Your loom should no look as neat as ever and still be the correct length.
Does that make any sense???
Rick
Its just a thermal switch, a piece of by-metal not sure how drawing a higher or lower current would cause this to switch at a different temp? I could be wrong, i'll look into it lol
Rob,
Old 03-02-2010 | 11:54 AM
marc_gti's Avatar
marc_gti
great idea, i will defo take one once done
Old 15-02-2010 | 12:10 PM
Stu @ M Developments's Avatar
PassionFords Creator
Testing is being finalised today, wanted to test them on a few different spec cars to ensure we can always switch in and maintain around 5 - 7 degrees less than usual and it looks like these will be available for sale by the end of the week at the latest.
Old 15-02-2010 | 03:05 PM
JTECH James
Passion for Fords!
Infact, Click me for a link to the webshop to buy them now!
Old 15-02-2010 | 03:14 PM
fiend's Avatar
fiend
There's a little typo in the last sentence of the first paragraph.
Old 15-02-2010 | 07:33 PM
JTECH James
Passion for Fords!
up
Old 15-02-2010 | 07:38 PM
marc_gti's Avatar
marc_gti
where exactly on the car does this go? sorry for the stupidity lol
Old 15-02-2010 | 07:44 PM
JTECH James
Passion for Fords!
on the thermostat housing
oldschoolfords's Avatar
oldschoolfords
the one whapped on mine today works a treat guys! cheers for getting it sorted pulls much much better!!! (f233eub) 2 thumbs way way up!
Old 15-02-2010 | 07:48 PM
JTECH James
Passion for Fords!
Old 15-02-2010 | 07:51 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
the thermostat and fan switch that i bought off ebay for 3 quid is very good,its an 82 degree thermostat and the fan comes in when the temp needle hits the M on the NORM writing.ive had these on my last 2 rs turbos and had no problems
Quick Reply: RS Turbo owners, Fan Switch news!
