My question would be
what RPM spool up to a 1.6 CVH?
8.2:1 CR
stage 2 (16psi)
big valve ported head
I want to use street
pressure all RPM (2000-6500)
thanks
you your help
If the cars fully mappable then Yes you can expect the turbo to come in early but it wont be able to hold out upto 6500 probably 5000-5700rpm max.
if on mfi then not too sure.
also you may not need to run 16psi boost depends on what power you was after?
i misread your post, sorry, yeah a GT2554 should boost as low as 2000-2500rpm, but as above i'd eexpect it to be alittle restrictive over 6000rpm.
probably better to aim for a GT28 variant instead.
I do not want more 200-220BHP
street should not be more
I do not want to 28R
