Zetec turbo Question..
Got a Zetec turbo using a silver top 2.0 in my Rst. Using the Fiesta Rst flywheel for the cps ring on the back. I'm having problems with the cps, the gap between the sensor and fly wheel is to big.
Question is....... Is there different length cps sensors?
Which one should i use with the Fiesta flywheel? Don't really want to take the box out again but if needs must.
Cheers....
Cheers....
I am not sure which ones are which but yes there are different lengths!
I have a mondeo one in mine which is reading off a EFI XR3I 220mm flywheel. It works ok but I am not 100% sure its correct. I will be checking the clearences when the box comes out again in the next month or so. I am sure there are clearence specs in the manual.
