dam car! if the turbo is smoking will smoke come out of the breather aswel?
11-10-2009, 06:09 PM
as above my turbo is smoking like hell and as soon as am on boost blue smoke out of the breather? will the turbo cause it? thanks andy
11-10-2009, 06:15 PM
Bodger of Blackburn
if you've got smoke out of the breather, you've got ring damage.
11-10-2009, 06:55 PM
The annoying ginger guy
Yeh sounds like the oil rings to me. Does the pressure push the oil cap off. Check for oil in your intercooler aswell
11-10-2009, 07:20 PM
no its doesnt mate, its a new bottomend it smoke like hell once on boost
11-10-2009, 07:31 PM
focus rs 1672
11-10-2009, 09:47 PM
could it be any thing else
11-10-2009, 10:40 PM
Bodger of Blackburn
Quote:
Originally Posted by
andy130
not likely to be the turbo.
how are the stem seals? if they are well gone then it could be them, but they have to have fallen apart for them to be that bad.
13-10-2009, 05:10 PM
if its a newly rebuilt block try putting some thicker oil in it to set the rings what are the plugs like as in oily carbon or clean burn looking?
13-10-2009, 06:39 PM
andy130
to much crank case pressure
13-10-2009, 08:52 PM
so rings?
13-10-2009, 09:17 PM
andy130
so rings?
not necessarily could be your breather system is not upto the job.
13-10-2009, 09:25 PM
could that still cause the filler cap to blow of a high revs?
13-10-2009, 09:27 PM
Oil in the intercooler???? my car has a spec-r breather system etc and has oil in the intercooler...? what could it be?
It only ever smokes (a puff at start up) if it has been standing for a few days... valve stem oil seals i would have though. So why would there be oil in the primary intercooler pipe?
Rob,
13-10-2009, 09:47 PM
sounds like rings to me, you say new bottom end? done yourself? has the block been honed etc?
head gasket possibly gone between bore and oil gallery? was it a new gasket, skimmed block and head etc?
13-10-2009, 09:51 PM
check your breather pipe dude that goes to the inlet my one has a restricter in it
13-10-2009, 09:56 PM
Should there be a one fitted?
I was just wondering if there was a common fault with the breather system to cause oil in the intercooler without the car smoking?
andy130 have you run it it? stupid question i know! i guess if your rings aren't bedded in you could have excessive blow by?
Rob,
RsS2daz
14-08-2015 05:26 AM
Adam-M
22
10-08-2015 10:46 AM
CabrioTurbo
01-08-2015 11:04 AM
blocked ,
car ,
cars ,
cooler ,
escort ,
ford ,
inter ,
intercooler ,
makes ,
motor ,
oil ,
smoke ,
smoking ,
turbo ,
turboed
