arp head stud & nut kit
My brother has just bought arp stud and nut kit for his s2 and on the fitting instructions it says to only torque them to 60ftlb and thats it.
Has anyone else fitted these before and was that what yous torqued them too? just does'nt seem very tight
Thanks Steve
Thanks Steve
He has just re-built the engine not long ago using steel rods and wossner pistons he put a felpro head gasket on from burton and the arp stud and nut kit and the head gasket has gone already thats what made me think they were'nt tight enough ( he is running about 25 psi of boost but surely they should be ok)
tell him to put the stud and nut kit, along with the felpro gasket in the bin. Use std ford items. RSt's generally don't blow gaskets unless overheated, and happily take 2 bar of boost.
Rick
Rick
Yeah he was using standard ford stuff before and it was ok untill it snapped a rod then he thought about upping the power abit more and would like to run 30 psi so thought if he got a stud and nut kit and good head gasket it would keep everything in place but it doe'nt look like its worked.
got to agree felpro are crap ive gad four in my rs over the years and all of them have let go and the bore size on the gasket r too wide unless u r 20l zetecing(zvh) it or 19 cvh. in the end i had to go and buy a cheap head gasket 8.86p and its bean fine ever since(go ford mate)
Wye Valley Hardcore
Not really sure why people use Felpro gaskets on 1.6CVH's? They aren't a turbo gasket and the bore is too big.
Stick to standard Ford bits. APT and NMS cars have proved they are the best.
i had no running probs with the felpro but just like above was throwing 40 quid to burton every 6 months lol. every time i had a water leak or the car just slightly overheated within a few days the dreaded mayo would appear
Bananas!
I torqued mine up to about 75lbs/ft, even tho evry one has told me not to use ARP headbolt on a RsT, but they were free so I'm giving them a go. As for head gasket stay with the OE ford one.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
