whats it meant to be at when idle?mines is reading -5ish then heading up to 0.i cant for the life of me remember what its meant to do.sit at 0 etc.does this sound about right?
if its on mfi then the engine is at a vacum on idle and low revs so that is fine
Yeah mine is between -15 and -20, it does flap around a bit though. As Tim said it also depends on your cam, port work, etc..
If your not pulling much vacuum at idle (950rpm approx) then it could be a sign of piston rings wear, just like a compression test would be low for the same reason.
seems a bit low, should be around -20mm/HG
you don't measure vacuum in psi, only in mm of mercury
mines about -20 and lower when just coasting- glad to hear mines not the only one that flaps about a bit!
lol yeah i'm not sure why the vacuum is erratic at idle?
But yes mine also drops to about -25hg when coasting.
Originally Posted by xr2wishy
very true, a healthy amount of vacuum though, on a cold start it tends to be more(?)
Probably because the idle is a little higher on a cold start, if anything it would pull less vacuum cold because nothing in the engine has expanded and nothing is seating/sealing (rings, valves, etc..) as well as it will when warm.
