Whats the better piston. C20XE or Accrilte?
Wye Valley Hardcore
I'm going to build up a new bottom end as mine currently has I need to fit mine with steel rods and has a little piston slap, it's irritating me sounding like a deisel. But what pistons shall I use?
My current bottom end has Accrilite Forged pistons, but I found a set of early Mahle Forged C20XE pistons (very very cheap) so bought them. Which would be better? I know the XE pistons will give me comp ratio of 7.8:1 with a CVH head and Focus RS headgasket IIRC but not sure what the Accrilites have been machined to?
Also the Accrilites have been machined with flat crowns and I have been told that at higher boost they will possibly damage?
how do you know xe pistons will give you 7.4? Thy're for i highish power normally aspirated engine which usually means high compression. Whats the difference between the xe pistons and the let pistons that are normally used?
Wye Valley Hardcore
It's something to do with the cvh head having a bigger combustion area than the zetec head. CVH being 55mm to the zetecs 48mm? IIRC. Because of this the LET pistons will give a comp ratio too low for ZVH so higher comp XE's are used.
Wye Valley Hardcore
Right then. Sell the accrilites and use the XE's. Next question is what steel rods shall I use? I know the little ends Need opening up from 20.83 (?) to 21mm for the vaux wrist pin but would Eagle rods be ok to use? I heard something about them being the wrong length so messes up the comp ratio?
Wye Valley Hardcore
With a forged bottom end and the rest of my set up I should be able to see 300 bhp with a turbo swap which is plenty through the front wheels.
Mainly due to the fact I have a very well specc'd CVH head modified to use a Zetec headgasket which has a brand new Newman cam and solid lifters which I would loose alot of money on if I went Zetec and had to sell it. Plus I do like the way the Ford motorsport rocker cover and custom XR3 inlet look in the bay.
