boost tailing off
Old Aug 15, 2009 | 07:18 PM
Gregor's Avatar
Gregor
Default boost tailing off
Hello all.
I'm having some problems with my zetec turbo.
Trying to set my boost a little higher with a bleedvalve it can't hold a decent amount of boost.
Had a -31 on before and now put an even stiffer one on but it can't hold more then 0.8 bar (12 psi)
i'm getting 1.3 bar (18-19 psi) when the turbo kicks in but rappidly goes to 12
The turbo has some play but can that cause this drop at such low levels?
It's a 2 litre zetec turbo with stage 3 rst t3.
Thanks
Old Aug 16, 2009 | 08:26 AM
kidsRS's Avatar
kidsRS
"Ill check the stock"
I might be right in thinking you need to adjust the rod on your actuator rather than trying to raise your boost pressure with a bleed valve. I believe if you try to bleed too must with a bleed valve this produces boost spikes.
Old Aug 16, 2009 | 08:28 AM
crazycage's Avatar
crazycage
i bet your on standard valve springs
Old Aug 16, 2009 | 09:32 AM
Gregor's Avatar
Gregor
I'll give it a try, weird thing is when i bleed nothing it's at 12 psi but it doesn't mather how much i bleed it goes down all the way to 12 again.
I know it always goes down a bit but when i do around 18-19 it should hold about 15 at least.
Don't even know if i can adjust the rod more, you can hardly pull it out but it has only half the hole stretched.
No, i'm on area-six springs.
Should be ok for 7000 rpm @ 21 psi according to Ian.
Old Aug 16, 2009 | 10:56 AM
crazycage's Avatar
crazycage
my be the turbo cant flow enough for the engine ??
Old Aug 16, 2009 | 11:54 AM
Gregor's Avatar
Gregor
Hmzz.. Had it on my 2 litre ZVH and it pulled 1.3 bar till 6000 rpm and now it's already on 0.8 bar at 4500-5000 rpm.
turbo is quoted on 28 psi but i think that's for a 1600 engine.
Just wondered if it's becuase the turbo is on it's way ( 2 mm radial play and 0.5 mm axial play ) or it could be something else.
I'll try a 2wd cosworth t3 next weekend if all goed well so then i'll know for sure but if it could be something else i could try it before i swap turbo's.
Have to get something else anyway to run 1.5 bar to about 6800 but till i get that just want to know if it's really the turbo that's causing my problem.
Old Aug 16, 2009 | 06:08 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
sounds like actuator spring can't cope with the exhaust gases, try either another actuator or give it a little more preload.
Old Aug 16, 2009 | 08:08 PM
Rick's Avatar
Rick
how much preload?
Old Aug 16, 2009 | 09:05 PM
Gregor's Avatar
Gregor
Had a -31 on it last week with the same problem...
Originally Posted by Rick
how much preload?
Half the hole on the end from the rod on the acuator.
Old Aug 17, 2009 | 04:11 PM
safe-map's Avatar
safe-map
www.safe-map.com
as said, usualy half hole for pretension on actuator.
have you tried a dawes device for boost control?
I find they are more stable than the regular bleed valve.
Old Aug 18, 2009 | 08:34 PM
Gregor's Avatar
Gregor
As i said i have half hole pretension.
Nope haven't tried that yet.
Old Aug 18, 2009 | 09:02 PM
JamboRS's Avatar
JamboRS
focus rs 1672
what intercooler do u run??
edit : try a smaller intercooler ive seen yours and it looks too big,or check the prerssure before and after the cooler,id expect it to be a significant drop
Old Aug 18, 2009 | 10:24 PM
Gregor's Avatar
Gregor
I can expect a drop with the intercooler but as said, on the 2.0 zvh engine it held a 1.3 bar.. and it drops to 0.8 doesnt matter what boost i set it to and what it gets when it first kicks in that's the weird thing.
Or should i get a bigger turbo so the drop will be less? ) planing for a bigger turbo next season anyway.
Old Aug 20, 2009 | 06:01 PM
Gregor's Avatar
Gregor
well, put some more preload on the actuator but didn'tmake any difference.
Any more ideas?
Old Aug 20, 2009 | 06:51 PM
Rick's Avatar
Rick
where are you taking the boost feed to the actuator from?
Old Aug 20, 2009 | 08:22 PM
Gregor's Avatar
Gregor
From the turbo compressor housing with the bleedvalve in between.
Old Aug 22, 2009 | 09:28 PM
Rick's Avatar
Rick
try taking it from the inlet manifold and report back.
Old Aug 22, 2009 | 09:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
You thinking there is a pressure drop through the IC?
Old Aug 23, 2009 | 02:32 PM
Gregor's Avatar
Gregor
Took it from the inlet manifold to the actuator with the bleedvalve in between.
Plugged off the turbo.
Stil got arround 1 bar , even opened the bleedvalve more but with the same result.
Old Aug 23, 2009 | 04:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Does sound like the turbo doesnt have the minerals mate!
Old Aug 23, 2009 | 04:54 PM
Gregor's Avatar
Gregor
Thought so as it has some major play on it lol..
Have to get me something else then....
Maybe t34 or something?
Old Aug 23, 2009 | 04:58 PM
crazycage's Avatar
crazycage
whats the spec of the engine ?? and what do you want from it ??
Old Aug 23, 2009 | 05:12 PM
Gregor's Avatar
Gregor
Silvertop 2.0 zetec CR 8.5:1
Accralite pistons
Pec steel rods with arp
rover inlet
fmic
tubular manifold
2.5" scorpion system
Standard head appart from the area six valvesprings
want to run about 22-24 psi for now and whatever Bhp that wil give me
Old Aug 23, 2009 | 05:29 PM
crazycage's Avatar
crazycage
Accralite pistons
rover inlet
fmic
tubular manifold
well i would say that the head will hold you to about 280bhp so aim for that sort of power,on the cheap a t34.48 would be my choice .
Old Aug 23, 2009 | 05:55 PM
Gregor's Avatar
Gregor
Thank,
Was thinking about that and also a gt28 orso but they're a bit more expensive lol.
So a t34 .48 can do that pressure all the way up the revs?
Old Aug 23, 2009 | 06:02 PM
crazycage's Avatar
crazycage
Thank,
yes it will flow plenty on a standard silvertop head , a gt28 would be much nicer every where but they are over £1k with all the trimings .
i run a gt2871 on a blacktop and imo its about the best you can get on a road car boosts from nothing and holds it all the way to 7200rpm in any gear 1.3bar low boost and 1.8bar drag map ,bearing in mind i ran a 12.7 1/4mile on just 1.1bar .
Old Aug 23, 2009 | 06:13 PM
Gregor's Avatar
Gregor
Ok thanks ..
Had a look on the net and came arround the gt2871 at about $ 1100 abit pricy for me indeed but if i had the cash.
Also saw the cheapo chinese gt's for around 350 but not to sure on those.......
Verry nice figures for that turbo... hope to get one of those sometime later... for now the t34 will be the one for me i think
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
