best way to stop the oil leaking from the oil cooler
holy fuck if its not the sump its the cooler whats the best way of fixing it? iv heard ppl on here say mocal oil cooler set up stops oil pissing out?thanks
Where is it leaking from? The connections? They are very fragile and you are supposed to support the fittings on the cooler (with a spanner) whilst tightening them. If it leaks and the connections are tight, then its fooked, simple as I'm afraid.
