metering heads
metering heads
tried setting the mixtures on my s1 (mfi) but the adjustment screw is not the proper one..it has a small bolt instead of the allen type (i think thats correct?)..the car runs but is quite lean..co level only 1.6% instead of 3% so ive been told..what im wanting to know is can i put a longer bolt in it as i think the screw needs turning more clockwise to increase co level..also what other things have you done to replace seized mixture screws..cant seem to get hold of a good second hand 1 with allen screw intact and not seized..thanks
Balls Deep!
It might be that the bolt is simply the bung to prevent an air leak, and if you take it out the allen key adjuster is underneath, thats whats normally done. Otherwise If what you say is accurate then the metering unit will need stripping down to remove it if it is seized!!
thanks for that...when i removed the bolt the car cut out so does sound like a bung like yous said..i was getting a bit of difference in co level but not very much..do u know what direction the allen screw needs to be turned to increase co level..thanks again
Make adjustment and use your finger to seal the opening while taking a reading.
Remember that the original CO figure from Ford was 0.25%. To set it really rich is usually done just to compensate the fuelling for higher than standard boost.
lol never thought of that! thanks pal..probably pushing my luck here but what size id the allen screw cos mine looks like it tiny but has a bit of crap on it so cant see properly..its currently at 2% max CO at the minute..im aiming for 3.5%..is this correct roughly cos theres a few mixed comments on here and you seem to know what your talking about ha
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
