Series 2 RST Bumper smoothing help please!
Morning all.
What methods are you boys using to smooth out the trim recess at the top of the bumpers, plastic welding or filling & smoothing?
Want to do it on mine and would welcome advice from anyone who has either done it themselves or had it done for them.
Thanks
Thanks
its each to thier own really on doing this, but i wouls suggest roughing up the area and applying fibre glass resin to it, then some filler to finish and smooth?
If your going to do it yourself fill most of it with fibre glass first then do a thin layer of filler just to get a smooth finish if you just use filler it will sink over time and look gash
mark.
mark.
Thats how i did mine aswell
![](http://i82.photobucket.com/albums/j280/xrmalin/DSC00388.jpg)
fibre glass is the way i was always told to do things like this as filler will sink over time thats why if a cars been de-locked badly with just filler you can see where the lock used to be so you should always do the smallest skim you can get away with
mark.
mark.
ust the hairy stuff in the tins mate which you just add hardner to as trying to use the sheets just makes a big mess and involves a lot of sanding i thing its called p40 fibreglass filler
hope this helps mate
Parts Restoring Nutter
Leave it standard pal. Looks much better ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
To many good bumpers being butchered to death now and there thin on the ground.
Smoothed bumpers, clears etc are long gone, so many people going back to standard looks etc.. Just my opinion matey
cheeRS
Chris
cheeRS
Chris
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
