wat brakes fit behind softlines ??
i got rs7 softlines 17" wheels and need some better brakes there are some tar ox 6 pots for sale in the for sale room would they fit ?? or wat other options do i have wat would you recomend for 200bhp i need to stop lol
With only 200 bhp the Cossie 4X4 Calipers and 2WD Disc's would be well up to the job,and cheap,plus an easy bolt on job.Also,there's no way the standard brake master cylinder would move enough brake fluid for a 6 pot caliper set up.The brake pedal would be in the bulkhead!!!!! Regards,Micky
My mate runs 285mm Wilwood 4 pots under the 17" softspokes on his S2 RS Turbo, and there looks to be a bit more room left for larger discs.
I'd also recommend Compbrake, they do some bargain 4 and 6 pot kits for the RS Turbo with bells/rotors.
http://www.compbrake.co.uk/escort_rs_turbo.htm
well i got cossie 2wd discs with spacers and std rs turbo callipers at the moment with 2wd disc conversion on back is this a adequete brake set up is there anything i can do to improve these ?
That will stop a 200 BHP car no bother.As for futher improvements,fit goodridge braided hose's and dump the ABS.Also as mentioned,you could fit the 2WD front 4 pot calipers,but they need to be machined to fit.Regards,Micky
already got rid of the abs but more worried bout the load compensators or the back out braking the front as heard some horror stories
rs turbo from Greece...
this is the cheapest way to make good brakes!! Karlos have you got them?? Mine have arrived 10 days ago. But i will fit them in september because i want to fit many parts together...
Balls Deep!
Spacer... http://cgi.ebay.co.uk/RS-turbo-mk4-e...lenotsupported
Caliper N/S... http://cgi.ebay.co.uk/mondeo-mk3-2-0...lenotsupported
Caliper O/S... http://cgi.ebay.co.uk/mondeo-mk3-2-0...lenotsupported
Pads... http://cgi.ebay.co.uk/FORD-Mondeo-MK...lenotsupported
Discs... http://cgi.ebay.co.uk/FORD-Focus-ST-...lenotsupported
You can save money by getting everything other than the spacers locally as there will be no postage, which for heavy things like Calipers and Discs is quite a bit.
I paid £25 for a pair of Calipers, £13 for pads, and £30 for discs.
Hi Karlos
The minimum wheel size for this brake conversion is 16"??
Will not fit under original 15" wheel??
CheeRs
Hi NUTS RuS
I´m looking for buy the biggest brake conversion suitable for standard original 15" alloy wheel (for track days) and 17" RS7 Diamond cut alloy wheel (for road use)??
Which kit will be the best??
My car is a Ford Escort RS turbo S2.
Thanks in advance....
what about using a brake bias valve and adjusting the bias more to the front?,this is what i was planning to do when i upgrade my stoppers.
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
Red_bull
09-08-2015 08:34 AM
