rod bolts?
rod bolts?
Hi all,
At what power and torque level do you need to change rod bolts on 1.6 cvh. I dont know my current bhp level. Have you any ideas?
1600cc block
EFI
Stage 3 head with power engineering cam
twin pass cooler
exhaust
t3 turbo
1600cc block
EFI
twin pass cooler
exhaust
t3 turbo
YES I KNOW I CANT SPELL
nick from fast ford was running 230 odd bhp in his s2 when his engine let go (got to say took him a long time tho) upon inspection he said it looked as if a rod bolt was to blame. i think they are fitted as pice of mined and only realy needed in high reving engines..........its all a gess tho alto im building a frst cvh at the minit and i will be fitting arp's just to be sure
i use ARP's , first motor is still in my garage with a 50mm hole in the side from a rod bolt which let go
ARP's just give you that little peace of mind , you wanna gable on a 6 quid bolt set keeping your coupla grand motor together?
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
