will this fit my s2
will this fit my s2
just bought this intercooler for £170 will it fit my s2 also wheres the best position for the fan cheers
http://www.gumtree.com/london/65/34606965.html
hi
just been lookig at the picture again if you do it yourself bear in mind the distance from the end of the top pipe to your inlet crossover as it mght be tight if your using a dump valve on the top hose and also i would say the fans are front mounted not in between rad and i/c as the bend may be to tight but this is just going by the pic
you should look for a brand name and do an internet search to see if you can find the instructions
mark
mark
Well i got it in there but still need to do some tinkering to fix the right hand side of the rad.Made up a nice bracket for the right side of the cooler and fixed the left direct to the car.Also had to butcher the pipework top and bottom to get the angles needed.water temps running above norm sitting in traffic, had to fit the fan on the front and might need to fit a switch for it.Next is to fit a new actuator then a nice set up.
mark
marky_g
15-08-2015 10:43 AM
track.focus'd
12-08-2015 05:53 PM
