Pace double capacity intercooler (ERST)
#42
Back In The RS Game!
Would this sort of thing be ok or is it cheap tat, and would it fit striaght on or need to have modded pipes?
http://cgi.ebay.co.uk/NEW-FORD-ESCOR...1%7C240%3A1318
#44
It's single pass for a start and the outlets don't come out at an angle like the ones made for an rst.....if you know someone handy with a tig welder and don't mind cutting and shutting it could fit but how well it would work you'd only know once you'd done all the work and tested it.
#45
baffles me why people would consider buyin a pace double capacity cooler when full front mounts are just a few quid more! like cutting off your nose to spite your face, not to mention retarded!
unless of course they are finding them cheap and 2nd hand, to which i wil beg the question why are they for sale and why so cheap? owner got a front mount now? engage your brain much?
also baffling is how the dude is raving about them (clearly on commision from pace id say), yet id gladly bet he does not have an ACT gauge to even check the charge temps. run massive boost it may well do yes, keep down temps id safely say not
i wonder how comparative a helper monkey blowing on a standard 'cooler wud be to a pace double capacity
#46
half pace 1st come out in the ealry 90s. when thats all you had to use or a c-c at 800 pounds when they 1st come out. in the last 8 years they have moved on a great deal grs being one of the 1st to try a front mount late 99 iirc on c&b and matt bell.. then pace brought out the since pass front mount which is a top bit of kit. i could go on and on about this but i will not
#47
People keep sating front mounts are onyl abit more but from where - can anyone post a link as im considering this option too but at the mo can get a double capacity pace for £35
#48
PUG 306 GTI-6
#49
This post was originally put up by paul on behalf of one of our friends who needed to make the decision either the double capaicty or the front mount one. He has now ordered the Pro Alloy front mount one just to be safe.
As for a few quid more, its additional £160 between the two pro alloy ones but you do get twin fans with the front mount kit
#50
How much is it total m8? Also, i dont really like the openmouthed look and would like a more subtle look hence why i was thinking of a double capacity instead of a front mount.Can u still fit a front mount without hacking the bumper? If so, doesnt it get a bit hotter as there will be no direct air getting to the rad as intercooler will be in the way.
Mc5506
05-10-2015 09:57 PM
The Youth.
30-09-2015 09:59 PM
