boost issue
Old Feb 18, 2009 | 03:13 PM
orion88's Avatar
orion88
Default boost issue
eve on eand eve all
right rs turbo engnie efi
put it in my estate hads lotsa problems but 2 things
a why wont the rs start of any other battery i tried 1.1 1.6 2.0 and 2.3 battery and nout also jump from another car and nothin any idea?
and b
when i hit 4k on the revs it splutters like mad and dnt boost correctly like it coughs really badly however when i floor it the thing rocxkets so is this fueling?plugs leads of just in need or a decent set up
its standard as far as i can tell may have cossy green injectors
has a k and n straight through system super chip and 10 psi boost.
Old Feb 18, 2009 | 03:28 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
cossie greens wont work,even if they did they would be 100% pointless on a standard engine!
Old Feb 18, 2009 | 03:30 PM
orion88's Avatar
orion88
well the bloke i got the engine from said it had 265 bhp and there fore needed them?how do i check theyre cossie ones carl?
trust me i have not been a lucky fellow so far with this motor
Old Feb 18, 2009 | 07:41 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
no offence but 10psi of boost won't give anywhere near this power.
i'd say the injectors would be fine, but it sounds like the ecu isn't chipped to allow the boost you have as it'll be underfuelling.
as for starting, try the starter motor or the wiring to the starter.
Old Feb 18, 2009 | 08:51 PM
orion_crazy_carl
orion=mini saff
if its OFAC or OFAB EFI then the injectors wont work due to the inpedence they work at
Old Feb 19, 2009 | 10:19 AM
orion88's Avatar
orion88
wont work at all or just intermittantly carl?
xrwishy it starts fine of me rs battery just more of a curiousity as tgo why u cant start them on these batterys and i know its not running 265 lol i turned the boost to 10 cos i need it reliable lol
it is chipped already tho with the super chip i was thinking just needed a decent set up
had to remove the iscv aswell as it revs the tits of the car and sticks on revs when u back down
any ideas on that problem.have changed the iscv as well so it aint that
Old Feb 19, 2009 | 05:09 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i'd say you have an airleak on the inlet/vac pipe from the inlet.
that will cause the idle to sit high.
perhaps the rs battery has better cranking amps output.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
