Oil Pumps! As my last thread got WAY off topic!
I know people say that the high pressure oil pumps from Burtons, Kent, etc.. are crap and that a standard Ford item is the way to go. But does anyone actually have any evidence of this or is it just internet chinese wispers??
Whats wrong with them? Do they not produce higher oil presure? Are they unreliable and fail? Who has actually ran one and had a problem?
Keen to find out as i want to change my oil pump asap!
Thanks Fella's!
Thanks Fella's!
Quote:
Originally Posted by ©hatter Box
std ford pump is the best to get as it flows just what you want for std bhp or 350bhp.hi flow pump don’t mean shit every one that i know that puts a hi flow pump on 1 week later there engine goes bang.
Quote:
Originally Posted by mikemcc03
if its any good to u i fitted a high pressure burton oil pump an my oil light flickered at idle dnt know if it was caused by sumthin else but didnt take the chance of runnin it too long.. not sayin burton pumps are crap i just didnt look into why it flickered i had another good engine at a very good price so swapped em ova. thats just my dealin i had..
Exactly the sort of info i'm after! Thanks!
Any one else?
Any one else?
Recently freshened up my bottom end, reground crank,under size bearings ARP bolts and burton high pressure pump.Done about 400 miles,seems to be fine,pressures good considering i haven't done the cam or turbo
hope this helps
hope this helps
I had a high oil pressure oil pump on my car from Burtons, never had a problem with it.
I recently had to get a new oil pump though cause when swapping the crank oil seal it had to be glued on to the Burtons one and came off in a million pieces. The ford one i replaced it with went on perfectly (but then i guess it would being genuine ford parts designed to fit each other).
Get Ford!
Get Ford!
JK12
33
26-04-2021 12:09 PM
