Need help fitting New fuel pump on S2
![Unhappy](https://passionford.com/forum/images/icons/icon9.gif)
Hi mates!!!
I need some help about fitting a new fuel pump on my Escort RS turbo S2 `88
I had buy a new fuel pump on "Autospecialist", here is a pic:
![](http://img177.imageshack.us/img177/1699/product553dl6.jpg)
But the problem is that I can´t bolt on the out of new fuel pump with a plug of the older fuel pump, I don´t know what it is, maybe a pressure valve or something?? Here´s a pic:
![](http://img177.imageshack.us/img177/3379/1804081710zn6.jpg)
Maybe the older fuel pump not is the original one for Rst S2 so the new does not fit??
What will I need to fit the new one??
I´ll be waiting for answers..............
Thanks
Thanks
Hi i need new one aswell but their is no block off value like that on my pump . Why do u need new one like mate ? Am going to put new one due to the 2nd fuel pump relay has gone .
If you cannot put screw from fuel pipe to new pump, put another pipe with right screw on it so then can put it. I dont see another way to do it.
denbo: on my rst doesnt have so big cap on screw.
Hi Denbo and Dragsteer
Thanks for your post.
I think, not really sure, that my older fuel pump is from other type car other Ford Escort, not a original Escort Rs turbo S2, so you don´t have so big cap on screw.
Looking on Ebay I saw this:
![](http://img508.imageshack.us/img508/4302/101bpm9.jpg)
![](http://img508.imageshack.us/img508/4302/101bpm9.548256f150.jpg)
M12 banjo union (8mm pipe tail)
M12 dome nut
2x copper washers
Maybe with this I will fit my new fuel pump?????
CheeRS
M12 dome nut
2x copper washers
CheeRS
what you do... isnt so hard. just watch to dont mess + and -.
anvini: yes, this things on picture I have.
so just dont forget to dissconect battery +, and watch for + and - on pump.
Ok!! Dragsteer
Definitely I think that fuel pump is not the original for Rst S2, maybe for another Ford Escort but not a turbo Rs S2.
I would like to know it. And the best thing is that my car has worked with this rare pump installed.
I have same situation , when I bought car , it has some bmw pump on it. And work ok, but I have problems with start hot engine. how with original rst pupm is ok. good luck
Same like you.
Now I know the type of fuel pump i´ve got fitted, a friend of "rsownersclub.co.uk" Lukeduke told me that:
"My microcat says its a fuel pressure regulator for 1.6 cvh EFI (D/GB) FOR CATALYST WITH LAMBDA CONTROL. hope that helps"
So it is a incorrect fuel pump for my car, it is for EFI CVH and Rst S2 is MFI WITHOUT CATALYST.
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
