ERST Boost
Old 19-10-2004, 06:31 PM
JimmyFlo
JimmyFlo's Avatar
Default ERST Boost
just gettin my actuator replaced with a cossie -31. what boost can i run with standard ecu??
cheers
Old 19-10-2004, 06:47 PM
KSA-Cossie
KSA-Cossie's Avatar
s2 10psi s1 8-9 psi.
Old 19-10-2004, 10:22 PM
james_birch
james_birch's Avatar
10psi max but would recomend with winter coming up i would run 8psi!
Old 20-10-2004, 02:47 AM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
isnt 12 PSI safe? suerly with winter comming ACT's will be cooler
Old 20-10-2004, 07:56 AM
Muska
Muska's Avatar
doesnt a standard s2ecu cut out if you run it over 10psi? just something i think i heard so could be wrong...?
Old 20-10-2004, 08:41 AM
JimmyFlo
JimmyFlo's Avatar
anyone got a cheap chipped ecu?
Old 20-10-2004, 08:59 AM
KSA-Cossie
KSA-Cossie's Avatar
One on e-bay m8.
Old 20-10-2004, 10:06 AM
james_birch
with winter coming up you wanna run less boost cus thew cooler temps will make it boost more thats what happend to mine and i kept over boosting and killed an engine for it too!
get it chipped or run it at 8/9psi!
Old 20-10-2004, 10:41 PM
AKRS1
AKRS1's Avatar
Had mine set up to 10psi on a standard ecu and found it held 8psi didnt get any overboosting problems with mine
Old 21-10-2004, 09:18 AM
mattbibs
mattbibs's Avatar
mine only runs max boost on a cold night so id have it set up 1 or 2 psi under what you think it should run considering winter is just round the corner!
Old 16-11-2004, 05:14 PM
sufsRS
sufsRS's Avatar
wot do esrst's run standard????
Old 16-11-2004, 05:39 PM
fomoco90
fomoco90's Avatar
ksa74f/231bhp, several on ebay at the mo, even some Bayoo ones
Old 17-11-2004, 09:16 AM
andy_turbo1987
andy_turbo1987's Avatar
over 12psi an the boost limiter will cut in
Old 17-11-2004, 09:20 AM
escortrsmatt
escortrsmatt's Avatar
the boost limit on a standard ecu is 10psi any more that this and the boost limiter will kick in.the standard boost on a rs turbo (S2) is just a touch over 7 psi.
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
Mc5506
05-10-2015 09:57 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: ERST Boost
