2 Stage boost
03-02-2008, 04:44 PM
2 Stage boost
Ive been thinking about having a 2 stage boost switch on my series 2 whats the easiest way ? Will it need different maps for each position ?
03-02-2008, 05:15 PM
2 stage boost
03-02-2008, 05:18 PM
3dr Cosworth owner
Dont they have a switch linked to your amal Valve. I Think they make it run a bit rich on low boost and set it up right for the high boost. mate of mine had this on his s2
03-02-2008, 05:22 PM
Ok then
03-02-2008, 05:43 PM
Bodybuilding
Location: Cannot be identified by the information given.
here mate resized it for you before the mods remove it
03-02-2008, 05:53 PM
boost
Cheers mate your a diamond, thought id done that
Got no amal valve on mine im running dta
03-02-2008, 06:28 PM
boost
Thas 5psi more than you matey
03-02-2008, 06:30 PM
03-02-2008, 06:33 PM
boost
03-02-2008, 06:34 PM
boost
What am i doing wrong
03-02-2008, 06:35 PM
Ok then
03-02-2008, 06:36 PM
Quote:
Originally Posted by T28 RST
[IMG] [/IMG]
Nice pics david bailey.
03-02-2008, 06:37 PM
Bodybuilding
[img] [/img]
you need to put image tags either side of the link you pasted
03-02-2008, 06:38 PM
Ok then
Quote:
Originally Posted by KSA-Cossie
[IMG] [/IMG]
Its what hes doing wrong scudbook
03-02-2008, 06:54 PM
I knew that
03-02-2008, 07:07 PM
sig
Brilliant
thanks for the help people
03-02-2008, 08:47 PM
Skint Passionford User
*I think* you need to put a switch in-line with the earth running off your boost controller, that way, it'll run half boost with the switch on, and full boost with the switch off
03-02-2008, 09:38 PM
Get yourself an electronic boost controller
.....far better than pissin about with amal valves and the like, gotta greddy profec on mine and it's a great simple bit of kit and you can choose exactly how much boost you wanna run on low or high boost
03-02-2008, 11:47 PM
I think Turbo smart make something along these lines.
Gimmie a minute.......................
03-02-2008, 11:51 PM
04-02-2008, 11:02 AM
Escort Rs Turbo
Quote:
The file size is still to big
timsrs
13-11-2018 11:48 AM
Mark RS
12-10-2015 06:01 AM
gcfcos
59
06-10-2015 05:04 PM
Mc5506
05-10-2015 09:57 PM
Russ Payne
25-09-2015 08:29 PM
