Pistons
Old 02-02-2008 | 08:41 AM
philyS2's Avatar
philyS2
Default Pistons
This may be a stupid question,but what pistons would fit in the S2 block ie cossie or calibra turbo? or can u get the standard mahle pistons skimmed?
Just asking cos im getting the bottom end freshened up ie new bearings shells and rings,and am also going efi,so not much spare money to throw at aftermarket pistons
Old 02-02-2008 | 02:30 PM
Maki's Avatar
Maki
Default Re: Pistons
Skimm them to 1.5 mm and you'll be good up to 21 psi for sure
Mine is done like that and it's holding for long time now
Old 03-02-2008 | 12:29 PM
Fiecos Dan's Avatar
Fiecos Dan
Skimmed Mahle or AE RST pistons.
Old 03-02-2008 | 05:09 PM
philyS2's Avatar
philyS2
wot are ae rst pistons?
Old 03-02-2008 | 08:17 PM
Fiecos Dan's Avatar
Fiecos Dan
Mahle or AE
RST pistons.
They are 2 different makes, Mahles are as fitted as standard.
Old 03-02-2008 | 09:58 PM
rstdave's Avatar
rstdave
I'm running 245bhp@1.5 bar using unskimmed AE pistons with no problems...track, strip and top speed runs have been done with no problems with the bottom end (not up until now anyway lol). Poor mapping has alot to do with meltdowns and pistons failing imo, you're going efi so that shouldn't be a problem.
Old 03-02-2008 | 11:44 PM
Billy_RS's Avatar
Billy_RS
Buy these
http://cgi.ebay.co.uk/New-Old-Stock-...QQcmdZViewItem
Not mine, but cheap for new pistons
Old 04-02-2008 | 03:39 PM
philyS2's Avatar
philyS2
yeh going efi cos the mfi is too old now,got myself an ofab loom with a cossie 3 bar map sensor and crank sensor,it just needs the suppresor i should have the efi head and inlet manifold by the end of the week.So i just need the ofab ecu,festa fly wheel and the supressor
01-11-2015 06:53 PM
little bram
04-10-2015 12:13 AM
deathrider666
28-09-2015 06:12 PM
timsrs
22
24-09-2015 08:14 PM
ajamesc
08-09-2015 06:51 PM
Quick Reply: Pistons
