FRS Brembo's on a RS Turbo
#87
Its hard to get upgraded brakes here in OZ and some of the ozzy fords have brembos fitted so it would be easier to get and fit some of them, does anybody have the part numbers or measurments of the FRS brembos and discs. My son has a 1989 XR3I and i have a big T escos.
#88
No part numbers sorry, but i can try & find out for you
disc size is 323mm from a Focus RS![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Plenty of off the shelf conversions available for the Escos, but your sons car could use the same set up as mine. the calipers, pds, discs etc.. can all be found on Bgay if you are interested in the conversion
#90
Originally Posted by project rs
nice to see your getting there tony with this conversion and i guess we'll be hearing from you soon to back our words up with our wallets
335mm x 28mm two piece rotor and bell
The caliper is nearly as big as the huge 13.2" rotor to give you idea's of size
![](https://img.photobucket.com/albums/v53/tij909/P2080518.jpg)
![](https://img.photobucket.com/albums/v53/tij909/P2080526.jpg)
![](https://img.photobucket.com/albums/v53/tij909/P2080520.jpg)
#92
I have had to keep the badges off the calipers for the photos but they can come with Brembo, Porsche, Ferrari etc as per the O/E caliper
Also available in the new Porsche yellow, but we have a 6 week back order on the Carbon look ones.
Nicked Mr S1's pic of the Porsche Yellow caliper for guidance
![](https://img.photobucket.com/albums/v56/MrS10/DSC00298.jpg)
#94
i see the pics of your set up tony is behind a set of comps does that mean they'll only fit behind them or will they go behind more standard wheels too like my diamond cuts, p.s awsome piece of kit
#96
I knew that would be the first question because I posted that picture lol. Its hard for us to stock every single wheel type and offset just for pictures. Drop me a wheel off and I can check for you as that's safer than guessing what the clearence of your wheel is like.
#98
all these brakes are great, but what i cant help thinking is why dont you downgrade to smaller size wheel as that gives you the same increase in braking power and saves weight.
slapping 17's on std 260mm brakes actually has the same effect as fitting 240mm brakes to a std rs turbo, not alot of people know that!
#103
Originally Posted by rscabrio
im interested in some off the porker ones but i need them to go behind 16s so cant be as big as that
any brackets available for them
#105
#106
ok mate could well be interested andyrob what disks did you use and have you the plans for your brackets lol sorry dan no just the two calipers im afraid
#118
17" kit using the RS 7 spoke with the huge caliper now almost ready.
Enquirys / orders being taken![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
315mm x 28mm rotors with the massive Brembo caliper giving a 65mm pad surface area, bigger than the AP or RS options at a fraction of the cost.
Another feature of these calipers is the butterfly pad retaining clip.
Squeeze together in the middle and you can change your pads in under 30 seconds.
![](http://img.photobucket.com/albums/v53/tij909/P2080510.jpg)
#119
![Smile](https://passionford.com/forum/images/icons/icon7.gif)
guys, im interested in a set of brackets to fit frs cailpers and discs to a series 2.
please keep me posted for price and avaiability.
Thanks
Dave
Thanks
Dave
#120
