safe psi
Old Nov 26, 2007 | 11:02 AM
scortpower's Avatar
scortpower
Default safe psi
just wondering whats the max psi you would use on a t3, mine is at 15psi now but is this a safe option or can i put it up a bit more ,
Old Nov 26, 2007 | 01:12 PM
sm's Avatar
sm
20psi is the limit of a std t3 but that depends on condition really 18psi is best to be safe, dont go just winding the boost up as the fuelling wont be able to cope and u will melt the engine, get the car set up by a tuner and he will adjust the fuelling to match the boost
Old Nov 26, 2007 | 03:02 PM
RSmark84's Avatar
RSmark84
is the standard pressure 7psi?
not sure on this as ive got a bar gauge and its goes upto 0.7bar?
Old Nov 26, 2007 | 03:06 PM
Red_bull's Avatar
Red_bull
That's the standard pressure yes!
But bar and psi are too diffentent messurements.
0.7 bar is a little more then 10 psi
my car was also running peak boost of 0.7 bar
Old Nov 26, 2007 | 06:53 PM
DaveyBoyS1's Avatar
DaveyBoyS1
If you want to run 20psi you need to make sure you have the fueling to match... consult your tuner, don't just turn it up
Old Nov 26, 2007 | 06:57 PM
T28 RST's Avatar
T28 RST
Ok then
Listen to the advice above
Old Nov 26, 2007 | 07:20 PM
matt p's Avatar
matt p
As above good advice givem there but........
I ran 24psi through mine and it lasted wait for it..................
2 months
Old Nov 26, 2007 | 10:04 PM
scortpower's Avatar
scortpower
ok thanks it was setup a couple of months back to 15psi so shall i still get fuelling checked for 18psi ?
Old Nov 27, 2007 | 04:18 PM
sm's Avatar
sm
have it fully set up again explain to the tuner what boost u want to run and he can set the car up to ur requirements and advise u if there are any probs
timsrs
Nov 13, 2018 11:48 AM
focuspower
Sep 19, 2015 08:27 PM
cossirob
Sep 16, 2015 07:39 PM
marky_g
Sep 12, 2015 04:26 PM
