urgent help needed
urgent help needed
hi please help trying to fix my car the now its a s2 erst the car is going for a setup on saturday and now decides it doesnt want to start the problem is there is no dash lights when i put the ignition on the full pump doesnt run or anything has anyone ever seen this before? any help would be much appreciated
ignition relay
I had the same problem with my rs turbo the other day mate. Went into a petrol garage and turned it off then when i tried to re-start it there was just nuthin! The problem was one of the ignition relays which is under the bit of plastic under the steering wheel (dont no what to call it). try taking it of and check all the connections under there! i gave a few of them a move around and it was back to normal! Worth a go mate!
sounds possible that its an immobilizer problem!?
i know RST dave off here had an issue, as some immobilize the fuel pump,
and all the ancilleries, so dash lights indicators ETC
Re: ignition relay
hi thanks for all the replys safechav have checked all the fuses all ok, i dont have indicators either but do have hazzord lights ive got rear lights and parking light, the lights from the dash im missing are the handbrake light and oil light and that and the original story with the fuel pump not really that sure where to go from now thanks alot
That does sound like an alarm issue as said above......usually you would lose a whole load of things, you appaear only to of lost circuits that are commonly in the immobilistaion circuits.
Re: ignition relay
i just had a play around with some of the connections under there and all my ignition lights came on!
Re: ignition relay
JoeyBoyden
04-01-2024 02:36 PM
jessie_rs
11
03-06-2019 04:57 PM
rog
04-09-2015 12:10 PM
borboyous
22-08-2015 11:17 AM
