No Power After 4000 RPM
just want to make sure my cam is knackered (if it is that is)
i have a cvh35 at the mo and get no power after 4000rpm in all gears is that differenetly the cam or other issue with the engine?
i share the same problem, i've just fitted a chipped ecu and still the same! mine seems to be on and off all the time, i can drive down one road and have no power, drive down the next and its all back?!
yours sounds like a actuator that has gone soft.
thanks
sean
Re: No Power After 4000 RPM
Originally Posted by kay2
it wont be the cam fella that head has had very little use, you could really see the cam come im at about 4000 when i had it, have you had it timed up properly?
some times its the fitting, and sometimes its luck of the draw,
either poor item, cam or follower, or fault in oil flow or valve issue.
i've had 5 Kents in my Cvh's.
A 35 lasted over 30k miles, and still fine,
A 35, and a 34 fucked them selves after 2-4k miles,
A 22 one was fine, but cant remember the milage,
and i fitted a 35 about 4 weeks ago.
deathrider666
28-09-2015 06:12 PM
