Mk 5 Pedal mod gone wrong.... (really wrong)
Old Jun 28, 2007 | 02:51 PM
  #41
SafeChav's Avatar
SafeChav
Originally Posted by _P_
White quadrant + MK4 auto adjust pedal would fit together but the quadrant doesn't have teeth all the way on its circle so the quadrant will move freely when you use the clutch...
the teeth will be on the half of it where the adjustment is needed though
Originally Posted by mitchrst
so is this just for the ap paddle clutch ?
because i have a helix 4 paddle and standard pedal and i find it bites very
soon and hard to get in gear
You're not getting enough pull on the cable then, a bigger quadrant will sort it though i expect
Old Jul 4, 2007 | 08:47 PM
  #42
wing's Avatar
wing
did anyone fit a spring to the new pedal, just done this shit conversion to mine and it don't take drive til the pedal is 3/4 up
Old Jul 4, 2007 | 09:21 PM
  #43
SafeChav's Avatar
SafeChav
Which spring mate?
Pedal to the floor or a spring on the pedal to the quadrant?
Old Jul 5, 2007 | 08:39 AM
  #44
wing's Avatar
wing
pedal to quadrant, i seem to have a floppy pedal
Old Jul 5, 2007 | 09:10 AM
  #45
Karlos G's Avatar
Karlos G
Balls Deep!
I have the spring fitted also but you still get a floppy pedal, all you can do is adjust the adjuster bolt to take up the slack/play.
I think its because there is no longer a ratchet mechanism to self adjust, everything will always feel a little floppy becaue until you depress the pedal the cable is loose and the ratchet has nothing to engage its teeth into (which is why the spring doesnt do anything anymore).
Old Jul 5, 2007 | 11:10 AM
  #46
Noisy Boy's Avatar
Noisy Boy
well i am getting this mod so by the sounds of it i am gonna have a nightmare
Old Jul 5, 2007 | 11:11 AM
  #47
Noisy Boy's Avatar
Noisy Boy
i know someone who work with laser cutting, should i get a metal one made? and not use the plastic one?
Old Jul 5, 2007 | 01:08 PM
  #48
SafeChav's Avatar
SafeChav
You shouldnt need the pedal-quadrant spring, that only serves to move the quadrant for self adjusting purposes.
Old Jul 5, 2007 | 08:13 PM
  #49
Chris69's Avatar
Chris69
get it laser cut mate and forget about the plastic one, its wot i've done
Old Jul 5, 2007 | 09:11 PM
  #50
Micky's Avatar
Micky
Yeah and get a price for the laser cut one so we can all buy one!!Job lot /group buy anyone??????Regards,Micky
Old Jul 6, 2007 | 12:00 AM
  #51
R6Franky's Avatar
R6Franky
I need one asap so get that machine cutting
Old Jul 6, 2007 | 10:35 AM
  #52
Noisy Boy's Avatar
Noisy Boy
sweet
Old Jul 6, 2007 | 10:36 AM
  #53
Noisy Boy's Avatar
Noisy Boy
i will see if i can sort something out for us rs boys
Old Jul 6, 2007 | 01:46 PM
  #54
Wazzzer's Avatar
Wazzzer
I just literally chucked my AP 4 paddle in my old RS and it worked fine
Old Jul 6, 2007 | 02:26 PM
  #55
Noisy Boy's Avatar
Noisy Boy
with no pedal mod?
Old Jul 6, 2007 | 02:30 PM
  #56
SafeChav's Avatar
SafeChav
As i suspected
Old Jul 6, 2007 | 02:33 PM
  #57
Wazzzer's Avatar
Wazzzer
no pedal mod at all mate...
Old Jul 6, 2007 | 09:15 PM
  #58
wing's Avatar
wing
4 paddle with std cover i didn't do pedal mod, but with uprated cover i've done the same as micky works a fucking treat
Old Jul 7, 2007 | 10:49 AM
  #59
Micky's Avatar
Micky
Balls,wrote out a essay on my new thoughts and was'nt logged in,all lost!!! Might retype it at some stage.
Old Jul 7, 2007 | 11:09 AM
  #60
Noisy Boy's Avatar
Noisy Boy
dumb ass
Old Jul 8, 2007 | 12:05 PM
  #61
_P_'s Avatar
_P_
the teeth will be on the half of it where the adjustment is needed though ;)
Not at least in my case.... :)
But anyway, the mod is shit.
Old Jul 9, 2007 | 12:45 PM
  #62
ryan_belfast's Avatar
ryan_belfast
Join the club mate, i bust 2 on mine in 4 days... lol pain in the arse, 300bhp didnt help though lol.
Old Jul 9, 2007 | 07:12 PM
  #63
c.fogarty's Avatar
c.fogarty
T'rificc just ordered AP clutch today, so have all this to look forward to
Does anyone know the FINIS codes for the correct pedal & quadrant ???
Old Jul 9, 2007 | 10:01 PM
  #64
SafeChav's Avatar
SafeChav
c.fogarty if i were you i would just try fitting the clutch and seeing if it releases ok, you don't have to fit the mod at the same time as the clutch, so you have nothing to lose.
If a standard set up will release the clutch sufficiently you would be better sticking with that IMO
Old Jul 9, 2007 | 10:54 PM
  #65
janbanan's Avatar
janbanan
Mine was just bolted on with no mods and have been running smoothly (well, its a paddle, so I'm using the term quite loosely, but still..) for 8 months now.
Dis-engaging just like the std clutch did, no difference.
Old Jul 10, 2007 | 06:24 PM
  #66
GraphiteGray's Avatar
GraphiteGray
Hi all, im probrably going over old ground but can someone please explain how this mk5/6 pedal conversion replaces the old mk3 set up?
I have an AP fast road clutch on my RS and im having trouble with the plastic clutch pawl shearing its teeth and slipping after a few hundred miles, i have just busted the second one in as many months
The pedal on the AP website has an adjusting bolt fitted, does this replace the pawl on the old type adjusters? how does this work compared to the old type? do i need a mk5 or mk6 pedal or are they the same? do i keep the mk3 clutch cable?
Sorry for all the questions im just abit miffed with these clutch ratchets keep breaking, luckily it happened near my house and not at Castle Combe
Thanks in advance
Old Jul 10, 2007 | 06:50 PM
  #67
george escort's Avatar
george escort
mine snaped twice and i have a mk6 escort with ap organic clutch..... give me a metal one any day.
Old Jul 10, 2007 | 11:05 PM
  #68
SafeChav's Avatar
SafeChav
Thanks in advance
Indeed the bolt does replace the pawl, but as has been proven here fitting this to the earlier cars, when the correct adjustment is obtained the bolt is pressing against the quadrant at a bad angle and presents a lot of stress so it ends up snapping anyway
Did you make it to castle combe? Think i may have seen you on the track parade
Old Jul 10, 2007 | 11:27 PM
  #69
GraphiteGray
Cheers for clearing that up mate, was looking for a way to ditch that self adjusting cr@p maybe if i fitted a rubber stopper to the end of the bolt it'll stop the metal cutting into the plastic and breaking it?
Yes i did make it to Combe, and i was on the track
Old Jul 10, 2007 | 11:32 PM
  #70
SafeChav's Avatar
SafeChav
Its not so much the bolt that causes damage though, it just pushes the duadrant at an awkward angle and snaps the centre lug off the quadrant (see the pictures in this thread )
Ahhh i thought so, i said to rsdaz (who i was there with) that the grey/red lights are definately the way to go.
Half of them RSi's on track seemed like right old bangers, there was numerous people struggling to keep their cars idling when they were waiting to get on the track, and loads of them were bailing blue smoke out the exhausts
The one bloke had his mud flap hanging off aswell - couldn't do that myself i would feel embarased - yours was looking
Old Jul 10, 2007 | 11:55 PM
  #71
GraphiteGray
Cheers fella dont know about the other cars being old bangers though some of em are well mint was probrably the heat playing havoc, we were waiting for the RSi racer to get running and a few of the cars were getting hot Just wish i couldve let mine rip but im still running the engine in atm
Can hopefully get this pedal sorted and finish off the running in miles
You got that cabby sorted yet?
Old Jul 11, 2007 | 04:46 PM
  #72
SafeChav's Avatar
SafeChav
They just didn't quite live up to my expectations but as im sure everyone has worked out by now - im a fussy cunt The heat shouldn't make them smoke
You can give it a little bit of stick it'll be alright, just don't go go attempting any top speed runs
Nope, still sat there with the roof slashed etc, i put a new glass in cos a fucking cat was jumping through the hole in the window and sleeping in there
Almost definately going to break it or put a 3i lump back in and get rid.
Old Jul 11, 2007 | 07:21 PM
  #73
GraphiteGray
Right ive just bought the mk5 pedal and clutch quadrant on your advise safechav, so it better work
Am wondering whether to try the pre 95 quadrant with the pedal instead of the new one ive bought, the way i see it is after you chopped the new one about it looks the same shape as the older type. On comparing the two the early one looks stronger around the pivot hole compared to the later design
What was you expecting from the parade lap then, RSi's jumping through rings of fire?
Im going by the book with the running in, cos knowing my luck it'll go bang and if it does its off to the crusher
Whats stopping you from getting that cabby on the road? who cares if its got a slashed roof, you never heard of duct tape?
Old Jul 11, 2007 | 07:51 PM
  #74
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
would it not be better to mod the arm on the box rather than the pedal?
just need to braket out the cable further really, seems simpler than faffing about under the dash, i hate it in there
Old Jul 11, 2007 | 08:47 PM
  #75
dave_y's Avatar
dave_y
am looking into getting some metal quadrants made up.
not going to wait around for another plastic one to fail on me.
will keep everyone posted if i can get some done.
Old Jul 12, 2007 | 11:15 AM
  #76
Micky's Avatar
Micky
Good man Dave y,keep us informed.Did AP ever get back to you by e mail???Regards,Micky
Old Jul 12, 2007 | 11:34 AM
  #77
SafeChav's Avatar
SafeChav
f'cof i never advised it i said to you they are prone to snapping
Can you not read plain english man
The quadrants fitted to our cars are a "quarter" of a circle, hence where the name was derived from. There is no difference between a pre 95 and post 95 quadrant, its the pedal that varies. A post 95 quadrant is the same thing and still has the teeth on it for the pawl. Why exactly are you looking to fit one anyway
Yes i have heard of duct tape, and that puts me in the league with those RSi's i saw that wouldn't idle/smoked/had parts hanging off them - NO FUCKING CHANCE
if i keep it, it'll get repaired properly, can't stand bodging things up
Old Jul 12, 2007 | 02:02 PM
  #78
dave_y's Avatar
dave_y
nah not a sausage, useless mofos!
Old Jul 12, 2007 | 06:44 PM
  #79
dave_y's Avatar
dave_y
Am going to send my modified quadrant off to have copies made next week.
I'm going to use the one that is in my car (Series 2) at the moment, will post up a picture possibly tomorrow to show you what it looks like.
If people want one they will cost around £15/20
FAO Moderators - I shall purchase Gold Membership before i start selling them!
Old Jul 12, 2007 | 11:16 PM
  #80
MarkXr's Avatar
MarkXr
Just what I wanted to ask....
Oh and count me in for a metal one!
