locking wheel nut issue!!!
Old Mar 5, 2007 | 10:36 AM
5axo.rst's Avatar
5axo.rst
Default locking wheel nut issue!!!
Hi all,
the problem is I've lost the nut for the locking wheel bolt so I can't remove my S2 wheels from my erst as I want to put my RS7 spokes on!
Does anyone have any ideas on how to get them off. I don't want to 'easy out' them if I can help it... Is there anywhere I could get a nut that would fit? Ive tried Speedshack and they can't help.
Heres a pic of the offending bolt (in situ)
Cheers for any help offered.
Old Mar 5, 2007 | 11:22 AM
Matt_B's Avatar
Matt_B
long nose pliers in the holes and twist them??....if there not to tight anyway.
someone somewhere must have a master set but not sure where
Old Mar 5, 2007 | 11:32 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
If you're a member, try the AA or RAC, I believe they have the required tools !
Old Mar 5, 2007 | 11:50 AM
mentalasanything's Avatar
mentalasanything
Motorworld used to sell a tool called a gator grip. It was sold as a universal size socket and was made up inside of loads of little pins that moulded to the size/shape of the nut. But it was very usefull to wheel theives as it would fit into any locking wheelnut pattern
Dont know if you could get hold of one of those??
http://www.fasteronline.co.uk/gator-...et-p-2990.html
Lee
Old Mar 5, 2007 | 11:54 AM
johnny boy rs's Avatar
johnny boy rs
i had the exact same prob at the weekend. needed to get the wheel off and had no locking wheel nut. If you go somewhere like RSR or an alloy wheel saleplace they normally have a set of tools.
I had to call a mobile mechanic who had the snap on set cos my car is being rebuilt. Was like a socket he smashed over the nut and then as he undid the nut it bites in like a reverse thread and off it popped. took him 10mins to do all four and didnt even scratch the alloys
Old Mar 5, 2007 | 12:03 PM
mentalasanything
I did this on my old corsa, but I think that only works for bolts where the key protrudes from the bolt, his is countersunk
Old Mar 5, 2007 | 12:07 PM
kurdt5's Avatar
kurdt5
had this prob in october just gone on my S1.
we had to chisel the locking nut and fit a locking nut remover over the top.
took a while but got it off.
Old Mar 5, 2007 | 12:25 PM
johnny boy rs
mine were the standard ford ones with the three pins that fit in the centre so they would have had the indents and also had a casing that spun round on the outside. only a suggestion at the end of the day!
Old Mar 5, 2007 | 03:39 PM
RST Ski's Avatar
RST Ski
i had these exact locking nuts and also lost the key to mine, i smashed a old socket over them and undid them
Old Mar 5, 2007 | 04:03 PM
antony215's Avatar
antony215
Escort Rs Turbo
Thats how ive done it in the past
Old Mar 5, 2007 | 05:32 PM
turboloon's Avatar
turboloon
Default as above
get a soket that is slightly smaller and smack the whore on
Old Mar 5, 2007 | 06:23 PM
PeterD's Avatar
PeterD
im sure a 17mm socket does the trick, dont quote me though
Old Mar 5, 2007 | 06:58 PM
antony215's Avatar
antony215
Escort Rs Turbo
Seems that smashing a socket on it is the tool that 90% of people use
Old Mar 5, 2007 | 09:40 PM
bigchez's Avatar
bigchez
I have that key! where are you, quite happy to lend it.
Old Mar 6, 2007 | 06:03 AM
5axo.rst's Avatar
5axo.rst
Thanks to everyone for all the comments, really appreciated it!
Bigchez, I'm in Molesey, Surrey. SW London. Fairly near Kingston. You would be a lifesaver if I could borrow it! I'd return it straight away.
CheeRS again
JoeyBoyden
Jan 4, 2024 02:36 PM
Bailes1992
Sep 3, 2015 02:17 PM
rst-s1
Aug 23, 2015 07:56 AM
RSMK4TURBO
Aug 19, 2015 04:46 PM
Red_bull
Aug 9, 2015 08:34 AM
