2 problems PLEASE HELP
Old Feb 23, 2007 | 08:50 AM
Maxxeh's Avatar
Maxxeh
Default 2 problems PLEASE HELP
my battery light is on all the time and dosnt start unless i either push start it or charge the battery.
second problem is my ERST is idleing at about 1800 rpm. Also the car refuses to go on boost. it will struggle a lot on boost. please help.
please help thanx.
Old Feb 23, 2007 | 10:34 AM
antony215's Avatar
antony215
Escort Rs Turbo
Sounds like your alternators fucked
Have you tryed turning the idle down??
What hoses you got if there the standard ones they may be collapsing under boost
Old Feb 23, 2007 | 10:58 AM
Maxxeh's Avatar
Maxxeh
I just changed the alternator and battery a month ago.
Also i changed my idle to 1000rpm. ive also got full samco boost and coolant hoses.
Old Feb 23, 2007 | 11:12 AM
SaqsS2turbo's Avatar
SaqsS2turbo
check the wires comining off the altenator to the starter motor ent rotten mines were and it wasnt chargeing the battery which lead to the same fault as yours
Old Feb 23, 2007 | 03:47 PM
Mine was the same aswell ,think you can still get the loom from ford
Old Feb 23, 2007 | 04:34 PM
SafeChav's Avatar
SafeChav
As said check the wiring on the alternator. The thin blue wire is what you will be looking at. A certain member on here recently also proved the theory if you bolt the main charging cable to the BLOCK the light will stay on aswell (you know who you are )
As for the idling fault..............one that springs to mind, it may sound dumb..........have you even got an alternator belt on there! If the belt was to snap it would idle high seeing as there is no idle speed compensation, and would explain your alternator light also.
If the belt is all good, there will probably be a problem with your auxiliary air device
Old Feb 23, 2007 | 11:30 PM
antony215's Avatar
antony215
Escort Rs Turbo
Boost problem could be a spark related problem plug gaps/leads or coil mine had the same sort of problem changed the above and it sorted it.
Old Feb 24, 2007 | 07:35 AM
Alex_86's Avatar
Alex_86
the altenator belt.. eller viftereima, no ideea at what thats called on english.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
