piper 285t2 cam
Originally Posted by rustyrs
dont get a t2 there shit
Originally Posted by Andy_R
Nothing wrong with T2's IMO I ran one for a while and thought it was a great Cam. I've also seen good results with other cars fitted with them over the years. Where the "they are shit" comments come from I dunno
The Kent CVH35Cam is a great cam.
Really all depends on the spec of the car.
knowledge = power when it comes to instaling & setting up cams IMO.
ive had two t2 kits only seemed to last two months if i was lucky the tappets would stick and the cam would wear out ive been told this is because piper does not use new cams there are just reprofiled not 100% on that one tho
focus rs 1672
Custom
yeah i had that cam off you was still running good 8k after when i took it out
i think it just depends if you get a good one or a bad one same with the kent ones really
Even standard cams are prone to wear, but my run about Orion is about to roll over onto 110k and its got its original cam, its tapping a little bit, but has done very well.............
Go with a Kent CVH35 or a Nemwan. Piper's 285T2 sacrifices everything in the midrange to give a small blip more at the top end.
Drive cars back to back with the 285T2 and then with the CVH35 and you won't be fitting the Piper offering.
Mc5506
05-10-2015 09:57 PM
