cold start problem help!!!
Old Dec 31, 2006 | 04:56 PM
djmillsy's Avatar
djmillsy
Fife Radge
Default cold start problem help!!!
when i start the car in the moring ive got to keep the revs up or it just cuts out the was a broken plug on the choke changed that and the chokes working but its still bad at starting check for leaks there isnt any at all any ideas?
Old Dec 31, 2006 | 05:01 PM
antony215's Avatar
antony215
Escort Rs Turbo
Check and make sure theres a fuse in the heated seat slot in the fuse box
Old Dec 31, 2006 | 06:47 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
May be the fuel computer (the black one). Mine went fecked ages back and had the same problem until the car was warm.
Old Dec 31, 2006 | 06:58 PM
rsjay's Avatar
rsjay
Again please try thermo time switch plug under inlet maniflold, can cause over/under fueling at warm up
leaking servo will cause far too high idle
All the best mate
Jay
Old Dec 31, 2006 | 07:18 PM
djmillsy's Avatar
djmillsy
Fife Radge
is that the wee black one on the trottle body the plug on mine was fucked but i got a new one for it
Old Dec 31, 2006 | 07:19 PM
djmillsy's Avatar
djmillsy
Fife Radge
All the best mate
Jay
how will i know if the switch is worling ive checked the servo adn all is good there
Old Dec 31, 2006 | 07:21 PM
djmillsy's Avatar
djmillsy
Fife Radge
ill get it checked
Old Dec 31, 2006 | 07:28 PM
rsjay's Avatar
rsjay
Im sure i've got a spare mate can post it out too you if can find it.
Check plug under manifold its a brown sensor can fuck up had same bother with mineand replaced sensor but turned out too be a bad plug.
Let me know how you get on im just in livingston.
jay
Old Dec 31, 2006 | 08:08 PM
Mr S1's Avatar
Mr S1
No, sits on the bulkhead with the ECU mate
Old Dec 31, 2006 | 08:13 PM
antony215's Avatar
antony215
Escort Rs Turbo
ill get it checked
Mine had the same sort of problem when i first got it i put a fuse in the heated seat slot and it starts first turn of the key everytime now
Old Dec 31, 2006 | 10:37 PM
MikeyXR2i's Avatar
MikeyXR2i
The Electromagnetic pressure actuator on the side of the metering head, can cause a lot of problems, it can make fuel pressure drop off overnight, if its weeping petrol in its casing, making the car hard to start. Also the pressure actuator controls cold start enrichment as well as normal temperature enrichment. It constantly talks to the black ECU making fuel changes. Id make sure everything is right here first.
Old Jan 1, 2007 | 03:00 PM
mattyonline's Avatar
mattyonline
chaps wots with the fuse on the heated seats i take it you not keeping your piles warm
Old Jan 1, 2007 | 03:05 PM
antony215's Avatar
antony215
Escort Rs Turbo
For some reason putting a fuse in the heated seat slot in the fuse box sometimes sorts out cold start problems dont ask me why it works but it duz
Old Jan 1, 2007 | 03:12 PM
mattyonline
o ok sod the exspence i cant be left out i will have to check[/url]
Old Jan 1, 2007 | 03:19 PM
antony215's Avatar
antony215
Escort Rs Turbo
Well it work for me and many others but look at it this way if it dont work for you at least you'll have a spare fuse in case of an emergency
Old Jan 1, 2007 | 03:21 PM
mattyonline
confused about the fuse but now i no i have got spare [/quote]
Old Jan 1, 2007 | 03:22 PM
mattyonline
Old Jan 1, 2007 | 05:27 PM
djmillsy's Avatar
djmillsy
Fife Radge
check the fuse its ok its start easy then the revs come down and it stops
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
