metering head- fitting+settting up tips
I'm looking to fit a new metering head to my rst at the weekend as the one i have currently is faulty
Have any of you guys got any tips for fitting it and then getting the car running so i can fine tune the air/fuel mix??
any hints/tips welcome peeps so fire away
As a general rule, i personally, would:
1. Fit it.......
2. Before you adjust anything see if the car starts.........
3. IF it does....
4. Get it (as a BARE MINIMUM) on a CO analyser ASAP and DON'T boost it up
5. If it doesn't........check for fuel at the injectors with the pump running, and if it does that try adjusting the mixture screw fractionally until you can get it to start and then go to 4.
1. Fit it.......
3. IF it does....
i looked in the workshop manuals i have and there not much help i'm gonna look through me haynes 2moro so maybe more luck there
Cheers safechav i was thinking along them lines, my mate has a sensor(closed loop lambda i think he said) to setup the air/fuel but the thing has to start up first i just hope the new metering head hasn't bean messed with much!
Is there like a set position, maybe a number of turns clockwise or anti-clockwise that i can turn the adjuster to set it up at a standard level just as a base?? before i fine tune it of course
Not that im aware of myself. Just try and see if it starts mate. When i first did the cabby i had a fucked metering head that was overfuelling a cylinder and that started pretty much first time, it backfired like a slag aswell
Originally Posted by chunt69
Is there like a set position, maybe a number of turns clockwise or anti-clockwise that i can turn the adjuster to set it up at a standard level just as a base?? before i fine tune it of course ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
hint
thats the manual i have in ur link i can't find wot u mentioned though
I downloaded that manual aswell and i couldnt see a lot helpful in there unless your considering removing the engine
SO.............have you done it yet
Should be running by now takes half hour tops to change a metering head
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Should be running by now takes half hour tops to change a metering head ![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
its not the fitting it, its the booking time with the person whos gonna set it up for me
i'm rolling about with 5psi at the mo just to be on the safe side- my xr3i rules
to cut a long story short its not faulty as such, more damaged i spose- the fuel/air mixture screw(allen key) no longer works
the car runs fine at low boost(maybe a little bit lean) but i wanna up the psi a bit so i need to alter the fueling in order to not lean out etc
hence the replacement
Ahhhhhhh what a fucker. I had one with a rounded out screw aswell
Never a good sign either if you think about it![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
all done
i was sweating it a bit as it took the metering head a while to flow properly and adjusting it to start was a nightmare
now running a solid 10psi and a big smile on me face
Si B
12-09-2015 06:49 AM
