boost problems!!!!!
boost problems!!!!!
right im having a crisis im running a 2ltr zvh with efi head etc so running ofac fes turbo management was running 7psi on standard injectors fine but was told that i could run 14psi on standard injectors with a chip so on went the chip and a twist of the bleed valve but wen i accelerate its like im hitting a block come off the accelerator and straight back on and she hits 14psi fine so wot could be causing the block first of all??????????
anyone feel free to help plzzzzzzzzzzzzzzzzzzzzzzzzz!!!!!!!!!!!!!!!
focus rs 1672
is it the right chip
i mind when i had my fiesta that a stg 1 chip would only allow 12-13psi and stg 2 you need bieges to go with the chip,sounds like overboost cut
dont know it applies to you but suppose it should as its efi
get it set up with the new chip as its not just as simple as plug and play
hth
hth
JK12
33
26-04-2021 12:09 PM
