brakeprob when fitted rearbrakes....
hello,
I just fitted cossiebrakes in the front of the car and rearbrakes.... but now i have the following prob i don't have pressure... all the air is out of the systeem but i have the put the pedal 2 times down before i got pressure.... do you have any idea what this could be???
please help me
greets johan
please help me
greets johan
DOES YOUR CAR HAVE ABS? IF IT'S AN ERST AND YOU DO HAVE ABS, YOU SOMETIMES HAVE TO HAVE THE PUMPS SPINNING TO BLEED THE AIR OUT OF THEM I.E START THE CAR UP AND WITH THE FRONT WHEELS IN THE AIR PUT IT IN FIRST THEN REBLEED THEM ALL.
ALSO YOU NEED TO HAVE THE REAR WHEELS ON THE GROUND OR THE SUSPENSION UNDER THE CARS WEIGHT SO YOU CAN BLEED OUT THE LOAD VALVES. I HOPE THIS HELPS?
JONNY
JONNY
marky_g
15-08-2015 10:43 AM
track.focus'd
12-08-2015 05:53 PM
