not starting
not starting
Hey
Just had my engine put back in and we had it running but lumpy.. Went up to the garage today drove it in from the yard to sort the clutch but now it wont run, we checked the injectors and there not getting fuel? what could cause this so suddenly
Incorrect mixture?
Incorrect mixture?
Originally Posted by ballin
fuel pump
Originally Posted by addiction
how did you check for fuel at the injectors?
Originally Posted by NEWTON
has the fuel pressure droped,cos there mecanical injectors and rely on fuel pressure so they wouldnt open check the fuel pump mate or put a presure gauge in the fuel line
fuel
if you put the ignition on number two then you should hear the fuel pump priming if you cant then the pump is more then likely nackered. First check the fuse in the fuse box and the relay before forking out on a new pump.
Re: fuel
Re: fuel
DixieTheKid
11
06-06-2020 11:20 AM
TPM961
15-01-2018 10:50 AM
