mains/ oil pump issues
st170 breaking
ok had this engine for a while, when it 1st started it would be spot on but after a minute it would lose oil pressure (lamp flickering) and after a few seconds of this it would get a tad growly (not knocky but just noisier)
now i figured its gonne need a grind and some shells (like the other 4!!! engines in my shed
the shell (pic) seems to be over 1 side a bit too much, you agree??, its located propperly in the indent, while im on the subject the top shell is grooved but the lower 1 is solid, this right?? been a few months since i stripped a cvh and i cant remember
seems to sit further 1 side than teh other huh
![](https://i61.photobucket.com/albums/h50/racetechturbo/frst%20engine/Image023.jpg)
and viewed the other side
![](https://i61.photobucket.com/albums/h50/racetechturbo/frst%20engine/Image022.jpg)
top shell groved
![](https://i61.photobucket.com/albums/h50/racetechturbo/frst%20engine/Image024.jpg)
and as for the oil pump, its fooked hence im hoping that while it caused a drop in pressure it will also be the cause of the noise thus the lump will be fine with a new un fitted
![](https://i61.photobucket.com/albums/h50/racetechturbo/frst%20engine/Image025.jpg)
engines been together for very few miles so dont wanna split the head off or have the crank messed with too much as its recently been done
JK12
33
26-04-2021 12:09 PM
03-11-2015 04:08 PM
