Holding back on boost s2
When i put my foot down in second, it held back on boost, felt really flat, happens on and off, other times it accelerates fine, any ideas ppl?
yes, it defo can be the cam, but this is consistent - ie always does it.
Make sure the knock sensor wires are not shorting where they go into the plug. Also, make sure it's tight into the inlet manifold.
Originally Posted by TURBO BOI
Originally Posted by turbo.jon
Could it also be a worn cam as mine did this?????
mine used to do it when cold and get a little bit better when hot changed cam and its fine now just try knock sensor first
Do you chaps think that anyway possible this fault could also be caused by my actuater or turbo itself? if its not the knock sensor or cam?
The car has a collins actuater on it, maybe if it wasnt set up correctly would it cause this?
green plug on inlet manifold near the black pipe that goes to brake servo
is this it? its green. is there more than one green plug?
CabrioTurbo
01-08-2015 11:04 AM
