Sump Gaskets-which ones best?
Hi guys, when i converted me car to the turbo lump, i replaced the leaking sump gasket with a FAI one piece rubber item. However, once the car was all on the road, it leaked like a bastid, so replaced it again with another rubber FAI one on wednesday, and its still just as bad despite using sealer wen fitting it this time also. So, im gonna stop trying the crappy FAI ones(they seem too big to me) and was wondering what you guys have used. Im tempted to go genuine ford, but want to know which of the two types is the best to use, multi piece cork, or single piece rubber Also, would a uprated breather/oil seperator help it out a bit as well?
the cars currnetly standard bar exhaust and 57i.
cheers guys
Danny
cheers guys
Danny
Ford all the time, i had a leaky sump gasket, garage put in Motor Factor part which still leaked, then i bought a one piece rubber one from Ford and that solved all my problems
not the best oil leak to have i must say!
the only way I've ever managed to get the sump gaskets to seal properly was on engines that were sat on a bench on the top of the block rather than in the car, they are a compltete nightmare otherwise!
