What is needed for a EFI conversion
I was thinking to do a EFI conversion on my ERST
What will I need and is it a big job to do??
How much will it cost??
U'll need a frst head Inlet manifold ecu escort efi loom ( some one to fit ) throttle body throttle cable efi escort acc pedal . . . . . . . u may as well just change the whole engine lol
It Wasnt Me!
Heres a list of everything needed.
Loom Cosworth 2wd / 4x4
ECU Cosworth 2wd / 4x4
Pectel Board + Plug for fittment
Crank Sensor Cosworth 2wd / 4x4
Alternator
Alt Bracket + Tensionor + Bolts
Altenator Belt
Bottom pulley
Crank pickup sensor bracket
Throttle Body Cosworth 2wd / 4x4
Ignition Amplifier + Heat Soak Cosworth 2wd / 4x4
Injectors Cosworth 2wd / 4x4 start @
Inlet Manifold Fiesta / Escort EFI
Laser Cut Phase Disk
Charge Air Temp Switch Cosworth 2wd / 4x4
Fuel Rail Fiesta/Escort EFI + Bolts
Idle Valve Cosworth 2wd / 4x4
Throttle Position Switch Cosworth 2wd / 4x4
Map Sensor 3 Bar
Fuel Regulator Cosworth 4x4
Distributor
Water Temperature Switch Cosworth 2wd / 4x4
Inlet manifold bolts
Throttle Body Gasket
Bottom Pulley Washer
Throttle Cable
Throttle bracket
Water Temperature Sensor convertor
ACT sensor convertor
Bottom Sensor
Top Sensor Bracket
Top Pulley
Rocker Cover
Fuel Filter
Fuel Filter Bracket
Fuel Lines
Inlet Manifold Gaskets x2
Map Sensor Bracket
MFI - EFI Converter Plate + Bolts & Gaskets
Alternator
Altenator Belt
Bottom pulley
Map Sensor 3 Bar
Distributor
Throttle Cable
Throttle bracket
Bottom Sensor
Top Sensor Bracket
Top Pulley
Rocker Cover
Fuel Filter
Fuel Filter Bracket
Fuel Lines
Map Sensor Bracket
Alternator
Altenator Belt
Bottom pulley
Map Sensor 3 Bar
Distributor
Throttle Cable
Throttle bracket
Bottom Sensor
Top Sensor Bracket
Top Pulley
Rocker Cover
Fuel Filter
Fuel Filter Bracket
Fuel Lines
Map Sensor Bracket
Alternator
Altenator Belt
Bottom pulley
Map Sensor 3 Bar
Distributor
Throttle Cable
Throttle bracket
Bottom Sensor
Top Sensor Bracket
Top Pulley
Rocker Cover
Fuel Filter
Fuel Filter Bracket
Fuel Lines
Map Sensor Bracket
alot of that u may get as one unit ie inlet manifold may have inj rail throttle body idle air . . . . . . . . it'd b easier if u had a donner car to use
Fiesta EFi can be done much cheaper,
Escort XR3i loom,
Fiesta turbo, ECU, ACT Sensor, Map sensor, hole for CPS, and CPS.
Plus throttle cable and pedal,
Buy a crappy 90 spec 3i off ebay, and get some fiesta bits!
Escort XR3i loom,
marky_g
15-08-2015 10:43 AM
