wot fuel for my series 1
Optimax
If you run it on the normal 95RON stuff it will soon fuck up. Bloke I used to work with used to have one because it kept blowing up he said Fords were shit. He had been running it on normal unleaded. Wasn't his fault as the seller didn't tell him apparently
If you're ever in West London see the independant garage in Holland Road
Kensington for some good old 4 Star. Failing that a trip to your local airfield
should find you some avgas. No more det EVER.
just while we are on the topic of petrol if i used optimax and a octane booster would it make any difference to the performance of the car
Depends on how you/your tuner sets it up. It will allow you to use more ignition advance than normal. BUT if you run out of ALdon (of whatever booster you're using) whilst out driving, fill up with Optimax then drive
home very carefully not putting the motor under any load. Otherwise the resulting detonation will ruin not just your day but also your engine.
Originally Posted by Mr S1
Have to say lads I've only ever run my S1 on standard unleaded and NEVER had any issues at all...................
SMILER258
28-09-2015 09:04 AM
