Map Sensor
Old Dec 28, 2005 | 09:51 PM
Big Man's Avatar
Big Man
Default Map Sensor
Hi guys, would it matter if I ran a 3-bar map sensor on my large turbo escort cosworth? its stg 1 but I want to change the map sensor as I think it is goosed
cheers sean
Old Dec 28, 2005 | 09:59 PM
Rippers's Avatar
Rippers
Monte Geek
I just fitted a 3bar to my stage1 Esc Cos as I was convinced my standard 2.5bar was fooked and it sorted the problems I've had no worries since
Old Dec 29, 2005 | 06:39 AM
MONSTER's Avatar
MONSTER
Paul Ripley What were the symptoms to make you think your map sensor was goosed?
Old Dec 29, 2005 | 12:47 PM
sailorbob's Avatar
sailorbob
2.5 bar and 3 bar MAP sensors produce different voltages for the same pressure and you cannot interchange them without getting fuelling problems. Paul, I suggest you source a 2.5 bar to replace the 3 bar asap.
Old Dec 29, 2005 | 01:00 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
What he said. Basically the MAP sensor divides the boost range into voltage signals from 0 to 5v, so obviously you can see that that fitting the wrong MAP sensor to the wrongly matched EPROM would mean that the ECU would not be seeing true boost.
Old Dec 29, 2005 | 01:48 PM
Dave Henshall's Avatar
Dave Henshall
above = conditions for maximum smoke IMO
get the correct 2.5 bar one fitted ASAP,
Old Dec 29, 2005 | 01:59 PM
Mike Rainbird
Caraholic
i.e. 2 bar MAP sensor "sees" 1 bar above atmospheric (0-14.7 psi), this pressure is sent as a voltage signal to the ECU divided between 0-5v.
A 2.5 bar MAP sensor "sees" 1.5 bar above atmospheric (0-22 psi), this pressure is sent as as a voltage signal to the ECU divided between 0-5v.
A 3 bar MAP sensor "sees" 2 bar above atmospheric (0-29.4 psi), this pressure is sent as a voltage signal to the ECU divided between 0-5v.
Obviously running a MAP sensor not fit for purpose (such as in Paul's case), will mean that the car can run lean/rich. This is because when the the car sees it's max boost of 18psi, the EPROM won't see the correct voltage to go with this, and so will under / over-fuel.
Old Dec 31, 2005 | 05:38 PM
cossie_love's Avatar
cossie_love
but if you have a stage one chip with a three bar map sensor would that work?
Old Jan 1, 2006 | 10:52 AM
Dave Henshall
it may run, but not correctly,
generally, stg 1 chuips will utilise the std injectors AND map sensor, its not just a case of bolting bits on and hoping it works you could have a stg 1 chip that is specifically designed for a 3 bar map sensor, but i doubt it very much
Old Jan 1, 2006 | 12:41 PM
Rippers's Avatar
Rippers
Monte Geek
Hmm I'm getting a stage three done next month so I'll just take it easy till then, but since fitting the 3bar is been running mint, the over boosting and misfire has gone and its mega smooth now
Old Jan 1, 2006 | 12:54 PM
Dave Henshall
maybe, but it may well be running very lean, as the 3 bar map sensor will be telling the ecu that at 1 bar actual boost, the ecu will only be seeing 0.8 bar and fuelling accordingly, you only need to run lean for a couple of seconds and pop goes the engine
really, u'd be better off putting the 2.5 bar map sensor back on and it overfuel a bit until u get it stg 3'd
Old Jan 1, 2006 | 02:44 PM
Big Man's Avatar
Big Man
okay thanks guys, who can supply me with a new 2.5bar map sensor? Cash Waiting!!!
Old Jan 5, 2006 | 11:44 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
STAND CLEAR its gonna blow
its not overboosting because at 14 or 15 psi the ecu thinks its only running about 6 or 7 psi, and only delivering enough fuel for the lower boost level DONT DO IT ITS BAD, BAD I TELL YOU
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
