Gearbox Removal
Gearbox Removal
How does the actual gear lever seperate from the box itself? We've removed the circlip thingy inside the car under the leather gaitor but it still won't budge out of it's holder Surely you don't have to pass the whole gear lever & knob down through the transmission tunnel
Resident Wrestling Legend
what do you want to remove?
the gearstick or the whole cradle?
if it's the stick on it's own you just punch out a pin (the lower one, the upper one does the reverse lever thing) and give it a YANKK!!!!! and it should come out
you may need to wiggle it, just a little bit to get it to come out because it's possible stuck
Oh right we are on the right track then! Yeah it's the stick that we're trying to remove, we punched the roll pin out but presumed that there must be something else holding it aswell with it being stuck so solid But after removing this it should come off then should it?!
Originally Posted by THE RADMAN
when i did mine [out of the car] had to get acetylene on it!
What I mean is, they dont usually go far enough forward (ie into third) to come back from the block and past the floorpan..
Put it this way I'll bet you 50 quid you cant put the box back in with the linkage/stick attatched
Nah I won't even be attempting it Damo! Now it's out and on the bench I can, with the help of some swear words I'm sure, persevere with it and figers crossed separate the stick from the box
Fudgey
17-09-2015 01:06 PM
Si B
12-09-2015 06:49 AM
grishenko45
09-09-2015 12:58 PM
