Autronic rev counter
Hi to all, my mate just converted his Escort Cosworth to Autronic Ecu and wasted spark but is having problems with the original rev counter. It either revs slowly or twice it's actually reving. Any one can help please?
Thanks
Thanks
Mark
My other friend converted his escort to Autronic before and used the tacho adapter with no results! But we'll try our own if you say so! Thanks for the help
If it's a simple square wave convertor you need, there are others that do the job, I fitted one to mine, as tacho did not work with new emerald ecu, cost me £30, and a emerald part, so all easy, that was because I went from std coil to coilpack so needed a square wave signal.
1 Post
the std escos rev counter wont accept a basic square wave input, it needs a colappsing field back emf which peak to peak is much higher voltage than teh square wave
TPM961
15-01-2018 10:50 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
cozzy jeff
14-08-2015 05:46 PM
