My New Spec...
Old 09-04-2008, 07:54 PM
  #121
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Originally Posted by Yeti Racing
Great post Karl, just one question If I may...............
What would the losses be NOT having solid lifters fitted to a NMS modded head ?
Jason,
I thought we were going solid lifters on your engine??
Regarding the hydraulic v solid lifter thing...
I have been running solid lifters on most of my 500 + Hp engines for years (and have be ridiculed for doing so) but until you have tried it please don't knock it, it IS the way to go!!
Karl, you give too much away
Martin.
Old 09-04-2008, 08:03 PM
  #122
Bullett
Bullett's Avatar
Originally Posted by Paul Ripley
Yes it is mate
Old 09-04-2008, 08:05 PM
  #123
rapidcossie
rapidcossie's Avatar
Originally Posted by Fiecos Dan
So have you tested on same spec cams, but solid lifter spec?
edited my reply Dan....
I read it wrong.
Old 09-04-2008, 08:06 PM
  #124
rapidcossie
Originally Posted by martin-reyland
Jason,
Martin.
do the solids need constant adjusting Martin?
Old 09-04-2008, 08:16 PM
  #125
Franco
Franco's Avatar
Jason,
Looking at my choices, will chat to you before i decide!
Don't forget the LS2! I've checked the dude out and people reckon he's legit!
Old 09-04-2008, 08:29 PM
  #126
markk
markk's Avatar
Jason,
Martin.
i agree - my rally engines have run solid lifters for many years, for other reasons than just the power abilities.
Old 09-04-2008, 08:44 PM
  #127
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
awesome read. Nice input Karlos
Old 10-04-2008, 08:49 AM
  #128
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
I agree that any engine that is going to revved consistantly beyond 7500rpm SHOULD have solid lifters for the reasons stated. However, if an engine is going to be rev limited to 7250, then I see no reason to have them. However, I would listen to what my engine builder wanted in the engine after I explained how the car would be used. My 180mph 500bhp engine and Paul's engine are on hydraulics. However, for top speed runs, I personally would consider solid lifters essential.
Euan,
Just read Chip's comments regarding YUMs top speed run on that thread. When you hold the engine at high rpm for a long distance, the lifters get hammered that much, that they pump all the oil out of them . You can tell when this happens, as the valve gear suddenly goes all rattley at the end of the run. What effect this has on the engine is that the valve opening / closing duration goes to rat-shit, leading to a loss of power until the lifters pump back up again. It doesn't cause any detrimental damage (although the VE goes haywire to what it was mapped to, so the car can run very rich), but does increase the wear and tear on the valve train.
Running solid lifters negates this, but they become a servicable item and should be shimmed every 6-10,000 miles (or when the top end noise dictates it is time to do so).
Old 10-04-2008, 11:12 AM
  #129
Karl
Norris Motorsport
Karl's Avatar
Martin,
Edited to remove some technical content.
Old 10-04-2008, 11:31 AM
  #130
JamesH
JamesH's Avatar
Should back pressure not be measured just after the turbine housing Karl?
Old 10-04-2008, 05:02 PM
  #131
RWD_cossie_wil
RWD_cossie_wil's Avatar
No, because there is no restriction bar the exhaust from there, you are interested in the pressure between the exhaust ports in the head and the entry to the turbine wheel, as if there is more pressure there than boost pressure, how can the engine get rid of the waste gasses from the cylinders? (in very basic terms, and In my interpretation of things ) Don't forget this is a dynamic pressure as well, so even if the engine is doing 7500RPM and the turbo is spinning at 100,000 rpm, the turbine wheel and wastegate can only flow so much gas before reaching choke point, where it cannot physically 'fit' or flow any more gas through the avaliable holes
Old 10-04-2008, 05:44 PM
  #132
Kelv
Almost there!
Kelv's Avatar
all this input, i can gladly say im more than happy with what Karl and Martin have put across.
i drove Andys car last night, clocked up a few miles on part throttle and generally got a feeling how the package worked for those mild driving moments and its ability to plod along gracefully and i was very impressed, then gave it a few miles of full throttle, car was perfect - the smooth way it picked up and the way it seemed to grow stronger and stronger as the revs increased - a very well put together engine and a perfect partnership between Martoon and Karl.
im hoping mines going to be a stormer
Old 10-04-2008, 05:53 PM
  #133
bigpower
bigpower's Avatar
Kelv,
It is nice is all area's of driving isnt it!
Old 10-04-2008, 07:46 PM
  #134
Bullett
Bullett's Avatar
it will be mate.im sure of that
Old 10-04-2008, 09:43 PM
  #135
JamesH
JamesH's Avatar
Fair point
Old 10-04-2008, 10:38 PM
  #136
rapidcossie
wonder what the power would be without a restrictive exhaust?
Old 11-04-2008, 06:23 AM
  #137
Fiecos Dan
Fiecos Dan's Avatar
Who's engine?
As it would of been good to see the housing test done, with a head, cams and cam timing chosen for power not response.
Old 11-04-2008, 06:29 AM
  #138
Franco
Franco's Avatar
Can anyone smell something?
Old 11-04-2008, 07:39 AM
  #139
Mike Rainbird
Caraholic
Is it an autumnal colour and got something to do with a piece of anatomy on the face?
Old 11-04-2008, 07:45 AM
  #140
Franco
Franco's Avatar
Old 11-04-2008, 04:33 PM
  #141
NEIL A
NEIL A's Avatar
If i end up with the same turbo as you it will be interesting to see what the power levels are like, at a set boost level with my mongoose compared to your custom exhaust on very similar spec engines.
Old 11-04-2008, 04:52 PM
  #142
rapidcossie
50 bhp is there for the taking with a proper exhaust IMO.
Old 11-04-2008, 05:39 PM
  #143
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
What size bore you got Euan, 3 ½" or 4"?
Old 11-04-2008, 05:42 PM
  #144
rapidcossie
half the exhaust is 4" then its twin 3", rad.
Old 13-04-2008, 07:33 PM
  #145
foreigneRS
Testing the future
foreigneRS's Avatar
great thread
regarding back pressure - depending on the size of the exhaust system (and number of boxes, bends, length etc), then having the outlet of the external wastegaste returning to the exhaust system will in all likelihood have an increased back pressure over one that vents separately. it is simple physics as more mass flow will be going through the main exhaust system (although there are many factors involved and you would need back to back testing on different 'screamer pipes' to prove it)
Old 15-04-2008, 06:33 AM
  #146
Fiecos Dan
Fiecos Dan's Avatar
It will also disturb (sp) the flow if not done correctly, which will also raise the back pressure.
rsjonny
21-11-2014 10:53 PM
mk6turbo
07-02-2014 07:48 PM
Quick Reply: My New Spec...
