EsCos Boosting problem
Old Oct 27, 2007 | 10:33 PM
Gatecrasher's Avatar
Gatecrasher
Not welcome...
Default EsCos Boosting problem
Car went into limp mode the other day due to the throttle position sensor comming loose anyway after putting it back on and tightening it up the car would not go over 1bar of boost
After messing about with the amal valve i herd a clicking noise comming from it when the cars running anyone had this before?
had another amal valve and a brand new one on it and its still fcuked had to just disconect it for the moment to stop the click/buzzing noise
Anyone?
Old Oct 28, 2007 | 01:08 AM
Kelv's Avatar
Kelv
Almost there!
the amal valves do click when they engage/disengage etc.
if all you had wrong was the thorttle position switch then why are you trying to alter the amal valve?
have you tightened up the throttle pos switch at the right point/angle, and do you run a pectel monitor?
or even a secs monitor coming to think of it!?
Old Oct 28, 2007 | 07:59 AM
Bullett's Avatar
Bullett
cant help on this ben.
but can soomeone answer what limp home mode is?and do saffs have them?
Old Oct 28, 2007 | 10:03 AM
Fiecos Dan's Avatar
Fiecos Dan
The same/correct TPS was refitted,
Ben hasn't got a ECU monitor, so i fitted it by feel, so should be with in 3 degrees accurate, which should not affect the boost controll.
But if you want Ben, i can volt check it, to get 100% reading. and make sure its reading 100% accuaretly
Basically the ecu is not sending any signal to the amal valves when boosting,
but when it feels like it, is does it on idle.
Old Oct 28, 2007 | 10:49 AM
M.A.D.RST's Avatar
M.A.D.RST
Phone Martin
Old Oct 28, 2007 | 11:21 AM
Gatecrasher
Not welcome...
Its was clicking 10 clicks per second continuously like a machinegun under the bonnet or a bomb waiting to go Bang lol
wasn’t trying to alter the Amal Valve either, i did say above that after it was in limp mode once the problem was found and rectified I.E. the throttle position the car would not boost over 1 bar
As Dan said the throttle position has been set up manual and no i don’t have a pectel or secs monitor
Old Oct 28, 2007 | 11:25 AM
Gatecrasher
Not welcome...
Limp Mode is what the ECU puts the car in when it senses that there is a problem like when a sensor is down, it keeps you from revving or bootsing so you cant melt the engine but can still get home
Im sure someone a little more techy can explain it a bit better but that was my experience
Old Oct 28, 2007 | 11:31 AM
Gatecrasher
Not welcome...
what will that tell you Dan?
Old Oct 28, 2007 | 11:46 AM
Gatecrasher
Not welcome...
Originally Posted by M.A.D.RST
Phone Martin
Its not like i can just pop up to Birmingham so he can have a look at it i dont think he will be able to diagnose falts on the phone i mean i know hes good im sure he will see this post anyway
Old Oct 28, 2007 | 01:32 PM
Fiecos Dan's Avatar
Fiecos Dan
Means the tps can be set up to 0-1% when throttle shut, and make sure its reading correctly thro out the throttle positions.
Old Oct 31, 2007 | 12:48 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
As it didn't have an AMAL valve fitted, it may be that the chip has been designed not to run one, so when connected it is going loopy .
Just set it up as you have with 1.5 bar and forget about it, as on Monday it will be sorted for good anyway .
JK12
33
Apr 26, 2021 12:09 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
Mickeystewart
Sep 9, 2015 04:04 PM
markk
Sep 9, 2015 08:11 AM
