apexi boost controller
Old Oct 25, 2007 | 02:46 PM
stookay's Avatar
stookay
Default apexi boost controller
my mates got one on his evo , nice bit o bling for inside car , can one be fitted to escos ? or is their technology too old?
Old Oct 25, 2007 | 03:19 PM
Nash's Avatar
Nash
Cake lover!
Very good bit of kit and yes you can fit one to your Escort.
Old Oct 25, 2007 | 03:42 PM
Gatecrasher's Avatar
Gatecrasher
Not welcome...
Any pic's?
Old Oct 25, 2007 | 06:39 PM
GUZZLER's Avatar
GUZZLER
Gatecrasher that should give you an idea, when i fitted it properly i put it in the top din hole at an angle so you can see it better.
Old Oct 25, 2007 | 07:55 PM
Gatecrasher
Not welcome...
Very nice
how does it work then you have your car mapped at the top setting and the just turn it down to what low setting you want?
if that is the case can the Ecu work out how much fuel air ect is needed at the lower settings or does it have to be setup like this?
cheers
Old Oct 26, 2007 | 03:04 PM
DENNIS's Avatar
DENNIS
i have been using the apexi AVC-R for near 3 years now. Excellent piece of kit... as long as the engine was mapped correctly in the first place the lower boost setting will be fine. If you have any doubt, get it on the dyno and checked..
Old Oct 26, 2007 | 04:39 PM
Gatecrasher
Not welcome...
Thanks for the info Dennis
Old Oct 27, 2007 | 07:10 AM
RS_Gav's Avatar
RS_Gav
I get a few funny looks with the AVC-R in my 3dr!! Apparently the black ones were a limited edition run.
Looks nice with the BF Defi's too!
Old Oct 27, 2007 | 09:20 AM
DENNIS's Avatar
DENNIS
no problem.
RS_Gav
The Black was a limited run. I personally prefer the black. It is unusual to see these on the fords but they work so well, why not ??
Old Oct 28, 2007 | 12:19 AM
stookay's Avatar
stookay
thats a cracking install mate ,looks excellent, what did you make the surround out off?
Old Oct 28, 2007 | 08:50 AM
DENNIS's Avatar
DENNIS
Thank you, i made it out of a piece of stainless, i still have one if anyone needs one. I painted it black to " fit in " but can be polished..
Old Oct 28, 2007 | 11:35 AM
Gatecrasher
Not welcome...
Can you still use one o these if you have your car on Air injectors?
Old Oct 28, 2007 | 03:20 PM
DENNIS's Avatar
DENNIS
you would need to remove the air injectors, witch is not a bad thing, but yes.
the avc-r is much better at boost control and a lot safer than air injectors.
Old Oct 31, 2007 | 01:09 AM
Fiecos Dan's Avatar
Fiecos Dan
i used to run apexi avc-r on my cossie.
better than Air inj's for a few reasons, but some tuners dont like them due to them not knowing how to set them up correctly.
Old Nov 5, 2007 | 07:51 PM
GUZZLER's Avatar
GUZZLER
no problem.
RS_Gav
thats just what i thought, i wanted a bit more modern technology on my car so it has an aftermarket ecu, siemens injectors & the avc-r
this is how mine is mounted at the moment,,
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
