Removing kidney box
Old 21-11-2006, 10:03 PM
PewteRS
PewteRS's Avatar
Default Removing kidney box
I am in the process of fitting my Bailey breather kit but how the hell do you remove the kidney box coz it wont budge ?
Looking at other pics it looks like it just pulls out so maybe just brute force is needed ???????
Old 21-11-2006, 10:09 PM
cosmo V6
cosmo V6's Avatar
just yank it up fella
Old 22-11-2006, 06:20 AM
CosRush
CosRush's Avatar
Ive found that usually a combination of twisting is (to break the seal), rocking it back and forth as much as you can whilst also pulling it up.
If you can get the kidney twisted away from the block enough, you can tap the underside with a rubber mallet at the same time as pulling upwards on it.
It is only a push fit but probably has never been out before since fitting.........
Old 22-11-2006, 10:53 AM
redrsmk5
redrsmk5's Avatar
i used a pry bar as mine was rock solid too....i took inlet manifold so it was easier to get too.
Old 22-11-2006, 01:37 PM
cheftony1
cheftony1's Avatar
excuse my ignorance, but whats a kidney box ???
Old 22-11-2006, 01:45 PM
PewteRS
PewteRS's Avatar
Its part of the breather system located under the inlet manifold.
Thanx for the info guys i'll have another go if the rain ever stops
Martin I have got all the inlet off at the minute........tbh ther car is looking a little sad as i'm having a little clean and i'm putting the rs500 cooler on too (amongst loads of other bits)
You can see how clean the drivers side inner wing is compared to the passanger side. The cam cover will be off soon also
Old 22-11-2006, 01:49 PM
CosRush
CosRush's Avatar
otherwise known as the 'flame trap' its the breather section that is fitted to the side of the block and directs oil mist to the inlet plenum for reinduction (not really a good idea, but used for emissions).
Shaped like a 'Kidney' (sort of) its designed to allow the oil mist out but oil itself to flow back to the sump as the inlet and outlet are staggered hence the 'kidney' name.
Old 22-11-2006, 03:13 PM
JanDK
JanDK's Avatar
Me too... it wouldnt come of with ordinary brute force and there is NO room for hand tools and get a good wiew to
Old 22-11-2006, 05:27 PM
THE RADMAN
THE RADMAN's Avatar
if the manifold is off then just use a big screwdriver to put between the block and the kidney box,then lever it outwards,once the seal has broken you should be able to wriggle it to and fro till its loose and comes out if the manifold is on then its a bugger but you can knock them out from below again using a long screwy or chisel
Old 22-11-2006, 11:53 PM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
gonna want to do this to mine!? v soon just bin all the old stuff then i take it!? i gonna want to plumb into the turbo side too is that asking too much by asking how hard that is!???
Old 23-11-2006, 12:03 AM
Franco
Franco's Avatar
I used a..........
BIG FOOKIN HAMMER!!!
Did the trick!
Old 23-11-2006, 01:44 PM
PewteRS
PewteRS's Avatar
Originally Posted by Franco
I used a..........
Did the trick!
I think that may work
FRANCO I have sent my parts off to Christian mate........a big thank you for putting me in contact with him mate
Old 23-11-2006, 07:23 PM
Escos Jam
Escos Jam's Avatar
skelp it with a big chappin stick. That'l get the bugger out
Old 23-11-2006, 07:25 PM
rapidcossie
rapidcossie's Avatar
mine practically fell out
Old 23-11-2006, 08:12 PM
redrsmk5
redrsmk5's Avatar
Wow mate looks like you've been busy and youre finally fitting the cooler too!!!! If you lived a bit closer id love to help you out with both jobs.....They were an arse but i just love doing this kind of stuff. Nice to see youre having a little clean too
Adamski: Its easy really....I rang round loads of well know tuners in the northwest and midlands area for quotes on fitting and they were all a lot of ££££ or booked up for weeks so i got the manual out and had a go. If you have the time, patience, and the right tools fitting the breather is easy.
I have a small turbo and so i havent gone into the rocker cover as after doing some research on the web it said that wasnt neccessary. I fitted a mirror image tank so i hope this is useful to you im not sure how different it is to fit the small round pot......On the turbo side underneath the manifold there is a threaded blank in the block that should just undo with a good socket. The narrowest port from the bottom of the mirror image tank goes from here to the threaded adaptor that you will get in the fitting kit.
There is a small pipe that goes into the sump on a 4X4 on the inlet side,pull this off and one of the ports (preferably the bottom one) from the tank connects onto this.
Once the flame trap is out of the block you need to fit the other pipe in the fitting kit into this hole for the remaining pipe to fit too.This should go onto the top port of the mirror tank.
The remaining pipe should be the widest one which just vents to atmosphere at the bottom of the car.
Hope this has helped......i searched on here a lot before i attempted mine as its widely discussed and theres some great information on fitting breather kits and pictures on here if youre willing to look.
Good Luck
Old 23-11-2006, 09:10 PM
adamski frst
i can do it no probs just curious how hard the turbo side can be
i have my breathers etc i just need to order some hose and quip fittings, and i also need to find myself the adaptors for the block or get them made....
does anyone know the size of the holes the adapters go into?? as i may get some adapters made with quip ends
Old 24-11-2006, 06:32 AM
Franco
Franco's Avatar
I used a..........
Did the trick!
Nice one my man, they'll look trick when they come back!
What bits did you send?
Old 24-11-2006, 01:56 PM
PewteRS
PewteRS's Avatar
I used a..........
Did the trick!
He's doing my cam cover, thermostat housing, strut tops, bailey breather, lifting eyes, inlet manifold/plenum and the throttle cable bracket.
I got a full set of black Roose hoses and mikalor clamps to go on too.....i cant wait to get it all back together
Old 24-11-2006, 02:14 PM
Franco
Franco's Avatar
Pics when its done mate!
Old 02-12-2006, 05:56 PM
PewteRS
PewteRS's Avatar
I managed to get the kidney box out after with a fooking big crow bar and i butchered the kidney box for the pipe to go back in for the new breather .
FRANCO Christian told me my parts are done so i should have them early-mid next week
Old 06-12-2006, 07:49 PM
PewteRS
PewteRS's Avatar
Pcs up here mate https://passionford.com/forum/viewtopic.php?t=237992
Old 21-02-2007, 12:25 AM
adamski frst
BTTT for the man who is gonna attempt this V soon
anyone care to describe the best way to remove the inlet etc and if i need to replace anything while its off etc
cheers Ad
Old 21-02-2007, 07:47 AM
Rolls
Rolls's Avatar
DO you have to remove the inlet when doing this?
Im thinking that I should remove mine as my breater still has it ( i think), but i have a horrbible feeling that if I remove the inlet, then rather than becoming a quick parts fitting exercise, it will become a full blown bloody rebuild etc... - not that any of you have gone down the same route, of course!
Dr. Ickxs
15-09-2015 10:15 PM
grishenko45
09-09-2015 12:58 PM
andrewmctiernan
08-09-2015 03:05 PM
Rizlablue
06-09-2015 09:58 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: Removing kidney box
