mk2 rs2000 cosworth build new everything.updated 09.05.10
#44
car shell in primer
in paint before clear coat
with clear coat
BIG THANKS TO J FOR ALL HIS HARD WORK :thumbsup: :thumbsup:
still got to be rubbed down and polished and have the rest of bits done
with clear coat
#47
looks nice,those x-pack nosecones warp like fuck in a booth with the temp right up.only done a light bake on mine in the end,it also put the arch kit out of shape
#63
well done mate, been watching your build and its looks nice and different, AND as well as that how you want to build it... you always find that some one duzz not like somthing on the car, but as long as you like it, thats all that matters, i had tha same problem with my car, they love it or they hate it... keep up the good work....
#67
what do i need to do the fit the cosworth in the car i have all the body mods needed
just sent of the sump to be big winged with baffle plate
also having the plenum mob done to get more air
using the 4x4 manifold
just need up now as i know nothing about the cosworth engine or wiring one up lol
#70
your breather
is that one from the rocker to the tank and one from the block to the tank? just im thinking about adding one but dont know anythink about them or fitting one????
#71
Love it.............and I think that's because it's different
At first didn't like the look of the wheels and thought it'll be too bling.
I was wrong wasn't I
Looked at this colour a good while ago but it wasn't available as Ford wouldn't release the colour code until the RS Focus was released.........very nice.
#73
warning
hi fostersice i just noticed that your top mounts are up side down the raised bit is supposed to be on the top as that is where the strength is the flat bit that you have at the top is the side the bearing is pushed in & only held in with a circlip it is not meant to take the weight of the car please turn them over fella.ps top car love it.
#74
warning
that way when i set every thing up i could flip it over so i have a nice new looking top mount lol..
i now have
bailey turbo damper
sparco sprint v seats
t5 gearbox
big wing sump
baffle plate
plenum mod
so i will be posting some more pics soon
#75
hi guys some more pics
bailey turbo damper (found out i dont need it when using a 4x4 manifold but hay it will look good on there lol)
cosworth 2wd sump thats been big wing'd mod'd to fit mk2 Xmember (done by russel brown of DB CUSTOMS 07725902960 OR EBAY USER DEATHBOX666) a real work of art.
DB CUSTOMS sump baffle again a real work of art
mod'd oil pick up pipe done by DB CUSTOMS (4x4 pick up pipe made longer to go with the mod'd sump
pick up fitted
big wing sump fitted
carbon look door cards
sparco sprint v bucket seats
RS cosworth wheel centres
some more pics of the car
pick up fitted
#76
Mate, I cannot get into words how good i think this car is, and I cannot wait to see it done.The strange thing is, for such an old car, that a lot of the subtle touches you have added really bring it up to a modern look Top work
#80
i need help now for the first time :-(
i now have the 4x4 engine back to gether
the mod'd 2wd sump
and waiting for the plenium to come back
2wd t5 box has been sent off for rebuild
have standard 2wd ecu and engine loom
but then im stuck
i need a fly wheel 2wd or 4wd one? are they the same
alt + mounts are 2wd and 4wd the same
starter motor are 2wd and 4wd the same
the mod'd 2wd sump
but then im stuck
