circuit board help please urgent !!!
Whole board snapped in half, or just a few tracks ?
Whole board repair would be difficult but doable, few tracks would be easy.
I wouldn't vouch for the repair's ability to withstand vibration in either case though.
The above applies to single or double surface boards, if the board is a multi-layer type, forget it, unless you are prepared to replace the broken tracks with soldered wires which would require a complete circuit diagram, and, would only work if the circuit isn't dependent on the layout (e.g. high speed data transfer applications).
its a pioneer rca adapter, one track is snapped on the underside and im 90% positive its just a single layer board
completely my fault so i only have myself to blame lol
matt
matt
matt
matt
i was thinking a small dab of solder just over the track could poss fix it
doug, now youve lost me lol
do you mean for a board that is snapped in half of just the one track ?
ie the board isnt snapped its all intact its just a track that i have snapped
The wire resolves that issue.
But as Frog said, a link wire from one side of the break to the other side would be a much better repair.
DixieTheKid
11
Jun 6, 2020 11:20 AM
