what camshaft?
what camshafts do you recommend for having a bit of power low range aswell as power from 3k upwards as i dont want to sacrifice drivability as it would be used everyday so would just like to add torque and power? after market or standard if after market what ones?
Originally Posted by Oranoco
CVH35 or Newman. Wouldn't use Piper 285T2 as a paperweight nevermind as a cam
285T in mine, no idea what the difference is but its done me fine. Lots of low down torque and lots of top end power
Although the rest of my spec may have somthing to do with that rather than just the cam
Originally Posted by turbo.jon
I would go std mate as been hearing few bads stories about some makes of cams wearing very quick
had a kent cvh35 in mine but its worn so im fitting a std 1 back in it....
Although the rest of my spec may have somthing to do with that rather than just the cam Trending Topics
I fitted a piper t2 in mine the car was undriveable off boost and had to wait till over 4k for the turbo to come in.
I then fitted a std cam had it all set up again and came away will a nice 225hp and a car that was soo much better to drive
I would say a kent cvh 34 as i personally think it's a cracking cam profile for low down torque, and still pulling at the top end. But i've had some really bad experiences with their cams wearing prematurely, twice in fact. If u could get a newman cam with a cvh34 profile i reckon it'd be ideal!
not heard nothing about newman cams though
i am also in the market for a cam and unsure as wot to get, thinking standard as im only holding 12psi but not keen on having to change if i go bigger power, wot sort of boost is the standard cam good for ie; wot power..
so if i have 12psi exhaust and filter but want more power later on maybe a zvh wot cam should i go for now.? i have a lovely rattle coming on so it really needs sorting asap and its not wise to just change the tappets.?
Originally Posted by JesseT
You won't see very big gains with performance cams unless you can tweak the ignition map to suit it.
Originally Posted by Rallyesport
A special ignition map is not needed.
just ive heard a lot bad things about the new 1s wearing quick...
*a very respected tuners opinion*
"The 285T2 will never be right! Piper copied the CVH35 and altered the LCA by 8 degrees so not to be had under copyright laws - The ended up robbing all the energy that was available to spool up a turbo in the 3-4k region, but gained slightly on the top end HP.
Most people buy a T2 and think it's a fantastic cam because it's hardcore at the top end, but any CVH35 owner will know the diff immediately as the T2 feels gutless until it's seriously ragged. "
when I had mine fitted buy the time the saff 4x4 turbo spooled up it was time to change gear anyway . Best thing i did was go std cam
yes standard engine, k&N filter magnex exhaust holds 12psi, i might go zvh later down the line or maybe 1600 on cossie managment, i need to finish my restom on my rs2000 first though, then i can start on the rst..
like i said the only reason im thinking of changing it is due to the noise and wondered if it would be worth putting in a higher spec one. CheeRS
for your help..!
for your help..!
foreigneRS
Technical essay Archives
Jul 20, 2004 11:29 AM
foreigneRS
Jul 20, 2004 11:06 AM
