Focus RS cutting out...
Old Jan 30, 2006 | 02:11 PM
Miss Black Puma's Avatar
Miss Black Puma
Default Focus RS cutting out...
Did anyone ever find the problem with FRS cutting out?
It's getting quite annoying!!
Thanks, Claire.
Old Jan 30, 2006 | 06:13 PM
JamesS2RS's Avatar
JamesS2RS
Default Re: Focus RS cutting out...
Thanks, Claire.
Do u have a d/v on it? If so is it a ggr one?
Jim
Old Jan 31, 2006 | 09:06 AM
Miss Black Puma
Thanks, Claire.
Jim
It's a bailey one. It cut out before we put that on though?
Old Jan 31, 2006 | 09:09 AM
JamesS2RS's Avatar
JamesS2RS
How old is the car?
Jim
Old Jan 31, 2006 | 12:00 PM
Willow's Avatar
Willow
This happens with some of the older ECU programs - took mine to ford and they did the upgrade for me - cured instantly!
Old Jan 31, 2006 | 12:13 PM
Miss Black Puma
September 03
RS53?
The car number is 4485 or something like that, it starts 448 anyway!
Old Jan 31, 2006 | 11:40 PM
Dog's Avatar
Dog
Have you tried disconnecting the battery for 20 minutes then reconnecting then letting it relearn the idle? Mine only stalled with a Bailey DV if you hammered it then ldipped the clutch at high revs as you pull up to a stop.
To relearn the idle once you've reconnected the battery restart the car and sit and make sure it doesnt stall by feathering the accelerator if required, once the idle settles to around the 7-800rpm mark let it sit for 2-3 minutes like that, then dip the throttle a bit and hold it about 2000 for a minute then lift and see if it stalls. If it does try it again, if it doesnt take it out for a good drive with a variety of high speed runs and it should settle back down.
Hope this helps a bit.
Rich
Old Feb 1, 2006 | 02:26 PM
Miss Black Puma
Yes if you hammer it then stop at say a junction or something it will stall, but he said it definately did it before the dump valve was fitted because he booked it in at the garage i work at and ive check the computer and we fitted an idle speed contol valve, which obviously hasnt work!
I'll try that though, we has the battery off when we fitted the K&N but I reved it up as soon as I started it ha ha!
Thanks guys!
Old Apr 6, 2006 | 02:03 PM
tonyk's Avatar
tonyk
My one does this after a service today, so they must have had the battery out. Gonna try the idle.
Old Apr 6, 2006 | 03:50 PM
Kev.H's Avatar
Kev.H
nope AF causes cutting out and the 5k cough
AE cause bogging down in first
Old Apr 6, 2006 | 04:29 PM
Willow's Avatar
Willow
Think that they put mine back to the AE to stop the cutting out kev.
Not sure to be honest - the tab on the inside of the door says ae and the test using the digi dash says 'E' not 'F'.
Old Apr 6, 2006 | 05:58 PM
spark's Avatar
spark
Mine must be running AE, it tends to bog down in 1st
Old Apr 7, 2006 | 09:32 PM
tonyk's Avatar
tonyk
how can i perform this digi dash test. mine stopped cutting out was fine last night and up to 8pm tonight. cutting out now.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
TPM961
Jan 15, 2018 10:50 AM
Si B
Sep 12, 2015 06:49 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
hopper350
Sep 4, 2015 12:53 AM
